Originally Posted by DEZ /img/forum/go_quote.gif
Thanks for the feedback. I assume my ONKYO should do a good job!
I read on some threads that the MS-2 gets a little scary on the highs(like 325), is that so?? How are the highs on the MS-2 vs MS1?
How are the highs on the MS2i vs MS-1?
Not a problem!! The MS2i has a slightly enhanced upper range, but it's more like an extended range which maybe can be considered a little "brighter" than MS-1. But in no way would it be considered scary!
What I hear when I compare the MS2i to the MS-1 is the MS2i is actually an MS-1; just MORE!! There's a bit lower and tighter bass, a bit more exact and fuller midrange and a more extended and clearer top end. The entire range is more filled out and "bigger" than MS-1 with somewhat more presence. Again; it's not a night and day difference, but it is enough more that, in my case anyway, while I can enjoy listening to MS-1 while on the computer and doing other things, when I'm listening to MS2i, all else stops while I listen to the tunes.
Right after I got them I did a fourteen hour "re-discover my CD collection" marathon! It was fun, and that was with BOWLS!!
They aren't perfect though. They don't do the big classical stuff all that well since the soundstage....which is a little bigger than MS-1...is still a bit smaller than that which is needed for classical. But they do acceptably for smaller choral works and chamber music sized groups. While I haven't heard the MS-Pro, I understand that they aren't exactly of that class either, but I have a feeling that for a pair of phones in this price range they do a very good job or representing themselves.
Some folks find the MS2i and the SR-325i to be a bit heavy, and some folks find them so heavy that they can't enjoy listening to them. They weigh about 100gm more than the MS-1 and SR-60, I did an "add 100gm worth of sockets to the height adjusters" test for a few weeks , uh, actually months, to see if I could handle the weight. No problem. But it is something to consider.
Anyway, to sum up: The MS2i IS better than MS-1 but it isn't $200 better from a SQ standpoint. When you add the workmanship and materials and style and all those other perhaps intangible things, then they may well be worth the price. And, they are a bit heavy to some listeners.
But nope, they aren't too bright!!
