Just got my new 2nd pair in. Looks mint and never taken out of the box, but it has a faint dusty smell from the box. Box looks like it came from the 80s! Still had the original price tag of $189 on it.
The difference for this pair is that the pads are much deeper. They almost seem to have a brown tint to them. You can see the drivers through the screen. Screen is totally clear. On my other K400 you can't see the driver.
Maybe I have K500 pads on my K400? That's what it came with. They have brown foam rings underneath the pad on the edges.
Does anyone know for sure if the pads with the brown foam rings are for the K501 or K500?
Still trying to hear any differences. Nothing sticks out yet. The Sigur Ros song "Gong" is painful to listen to, but that's generally the case on my other AKGs.
On the new K400 it sounds thin and very harsh.
EDIT: This pair is really sort of similar. Right now it mostly sounds thin and harsh. I guess I need to force myself to buy some K601 pads. I'll use Annie or Q701 pads until then.
K400 really does sound best with new pads. K400 stock is too bass light to me. At least the versions I have..doesn't mean I don't like it.
Just put Annie pads on it again. Think it really smooths out the sound a tad. The K400 to me is even more trebly to my ears than my Q701 (but not K702).
NOTE: Q701 pads definitely sound better than Annie pads on the K400. Not a fan of Annie pads really for some reason.
