nogi replicant
- Oct 22, 2013
Hello. I recently got to try the AKG K3003 and I really loved the sound signature. Unfortunately, the fit was too shallow for my ears and the isolation was not very good. The store let me try various tips, but no joy. I don't suppose anybody can recommend an alternative with a similar sound to the K3003, but with a deeper fit and better isolation. Thanks.
When I got my k3003's they were also too shallow. I fixed this very easily by cutting about 2 millimetres off the bore of some other tips and putting it on the k3003 nozzle and then putting my tips on. Essentially extending the nozzle by 2mm's. Fixed.
You could also try spin fit tips as they are long but I find they don't give great isolation unless pushed deep in your ears.
I think I used Sony Hybrid tips on my k3003's. They give pretty solid isolation.
Alas I lost my k3003's. They are amazing iem's so I wouldn't give up on them if I were you. After I got mine I liked them so much I sold my Parterre's and Lab 1's within 2 months.
