I was just comparing LF to EHHA. Liquid Crimson would be similar to those two, but only uses one E88CC tube instead of two. LG is a more traditional hybrid and LG is solid state I believe, so I didn't compare them.
Thanks for the info!
My new favorite cans: K240 Sextett LP
I can't say that I mind my pair!
Best price to performance I've gotten from a headphone by a wide margin. Paid 45$. Elastics are worn out, so I need to fix that, and I dunno about the damping materials. Sounds excellent as is but I wonder if they're at their best. Is there a thread that can walk me through replacing damping materials, elastics, etc?
http://www.head-fi.org/t/279905/taking-the-k240-sextett-apart-step-by-step
Huh. According to that thread, the foam makes zero difference in sound quality.
Thanks by the way.
the previous owner of these used tape and pen caps... I wanted to make them look good by replacing the internal elastics. How hard is this to do?^^ agree with that, just change out the old pads for new, I'm using the cheapest DIY of all, 2 rubber bands to pull the 2 earpiece's up to the headband
Di anyone happen to try Shure 840 earpads on the Sextetts?
They fit well w/o needing to stretch? Can you characterize the difference from the new K240 pads? Any recession in the mids?
