BRSxIgnition
Quote:I just received my pair today, and they are great. The only problem I have is that I think I may have a pair that has the gluing/loose headband problem. They stay on very well, but if I only slightly lean back, they start to slowly slip off my head. It only happens when leaning back, so it's not much of a problem, but it can be annoying. Is there any way for me to tell if my pair is V1, and do you think I should contact AIAIAI?
They must be V1. I couldn't see this happening with the set that I got, even if you have a relatively small head. Actually, maybe I can run a test with my fiancee and convince her to try them on. She weighs less than 100lbs and barely breaks 5ft tall. If they stay put on her head they'll accommodate pretty much anyone's.![]()
What should I do? Should I contact AIAIAI for a replacement? I didn't buy them straight from the manufacturer, but from Turntable Labs through Amazon. Would I even be able to get a replacement from AIAIAI for free?
You'd need to check if they are an authorized reseller of AIAIAI Products, if yes, then you're fine, if not, you'd need to fix them yourself or buy a new pair.
When you call or email them, could you ask if DijitalFix is an authorized reseller for me? Thanks, it would just make me happier knowing that if something goes wrong, I'm covered.
