Hi, can you please describe the difference in sound between HS1790 and HS1551, especially in the bass part, transparency of the sound, speed of the instruments and resolution.Hi all, I just bought an HS1790TI as an upgrade from my old HS1551CU because I want to enjoy the details oriented acoustune. However, my ear canal is quite small and the S sized eartips are the only ones that fits my ears. But because of this, the Bass became stronger. Does anyone have recommendation for the eartips type that will give me a better detail?
When I am using the TI with the small eartips, strangely enough it gave me a good amount of rumble, almost to the level of my old HS 1551 CU.
Strange isn't it? just changing the eartips can alter details, enough that even someone like me can notice it.
To me the HS1551 sound veiled, the HS1004 felt more clear and transparent with less bass, I wonder how much better the 17xx series is, especially the HS1750, thanks.
