Originally Posted by fraseyboy /img/forum/go_quote.gif
Cool reviews! Seriously, that format is cool
Just wondering... Which amp synergized best with your HD600?
The Mini^3 sounds excellent with the HD 600s. Very full sound. The Mini^3 is a very neutral, very detailed, little amp with great performance across the board. You get plenty of air around the instruments, very good width and depth to the soundstage and plenty of bass impact, but everything is in balance. The highs are also excellent, very clear and extended without any etched or cold quality. Another few instruments that sound really realistic and natural on this amp are violins, pianos and cellos. The high violin notes sound full and extended in the treble without any shrillness or metallic sound, the piano notes do not have hard edges like some amps will give you, but have a really full rounded tone like an actual piano, and the amp allows you to hear the decay of the note really well because it is so good at picking up low level detail and the ambiance of the recording. Another thing that is noticeable is that when you hear cellos you really get the buzz of them, you can hear the string friction and sort of "grind" that a real cello string sounds like, there is no blurring to the sound or artificial smoothness, you get a realistic sense that some "friction" is occurring between the bow and the strings. Even the more expensive portable amps that I own don't seem to capture this quite as clearly.
I am using the Rockhopper made M^3 with dual 8397s, the so-called, high performance version with a gain of 2. Even this low gain is sufficient to push the HD 600s to loud enough levels, but if you are not going to use sensitive IEMs (which I mostly use) then there is no reason not to get a higher gain version for use with the HD 600 or other similar cans.
I bought this amp because I was curious to see what it would be like and the price was attractive. I had no idea it would be as good as it is. So much so that it has become my everyday portable amp replacing the Millet Portable (at least for now) because it sounds equally good and is easier to carry. In some ways it actually sounds slightly better, particularly with rock music, but much to my surprise is excellent across the board, whether with classical, vocals, jazz, folkie accoustic guitar, or whatever you throw at it.
So, back to the initial question, this amp will sound quite good with your HD 600s.
