Xcalibur255
- Feb 4, 2008
My experience is with rectifiers, but I have no reason to think that drivers and output tubes would be substantially different....
I have Valvo and Telefunken AZ12 rectifiers, mesh and sheet metal, and in both cases the two versions were manufactured only a few years apart, with the mesh being the earliest and the sheet metal a few years later.
And in each case the most noticeable difference is in the highs, mesh plates are slightly less sharp. And to my mind this is due to the difference in the harmonic resonance of these materials. If you were to tap the sheet-metal plates, you would hear a metallic ringing sound. And if you were to tap the mesh plates, you would hear a very dull sound -- "damped" if you will. So it seems to me that the "ringing" of the sheet-metal plates is adding a bit more treble energy. And perhaps it is safe to say that the mesh plates are perhaps more neutral. Anyway, this is they way it seems to me. But of course, my ears and my gear...
I think you're on target here, it seems logical to me. Any mechanical ringing is likely to have an effect on the sound, just like microphonics. Ringing mostly affects high frequencies, and mesh has superior mechanical damping qualities. I see a lot of people mention that the soundstage feels more "layered" with mesh tubes and that might be a side effect of the reduced ringing.
I've been leaning towards doing mesh for a good while now, if for no other reason than if I'm buying special expensive tubes I might as well go for the most special version.
edit: of course what I REALLY want are those EML 45 Globes that they only made one time a decade ago. Every once in a while somebody lets their spare pair from that one-time buy go and I think they're closing in on WE 300b prices now. I will never have that kind of money to throw at this hobby so I'll have to settle for standard production meshies.
