Hello
@Ramenik, welcome !
I'm going to answer your PM to me on the open forum because I know there will be others who will be asking the same questions. So I hope to answer these questions for the sake of other prospective Glenn OTL amp buyers at the same time.
I'd like to quote your message if it's ok with you because A) you're a Singaporean (my fellow countryman) B) you're very sincere and courteous. I'm touched.
Hello,
I am Ramenik, a new headfi member and just getting into personal hifi.
Sorry for messaging you seemingly out of the blue like this lol. The reason I am writing this is because I hoped that you will be able to help me if I decided to get a Glenn otl, given your expertise in tubes. There are alot of information in the Glenn studios thread and a little overwhelming for a novice tube user like me.
I am in the process of moving from a stereo speakers setup to a desktop system due to family reasons (baby and a second one coming). Most likely getting a pair of aeolus or Verite after auditioning them last weekend. I have also talked to Glenn, but would like to talk to others with experiences with his amp.
I am just very confused over the different tube types, tubes and socket configuration etc. So would like to ask if you have any suggestions on the configuration to go for as a first time tube user like me. For example Glenn has asked me if I wanted one 6sn7 or two 6j5 and I was like ???. I would want the voltage switch for cheaper tubes, gold point volume, Jupiter capacitors and lundahl transformer that he suggested though.
Sorry for being so long winded lol. As I am diving in head first into this hobby, I hope to get my first steps right.
Thanks for reading!
Best regards,
Ramenik
I will get to the point. Since you ask me, I'll give you my opinion. It's mine and I make no apology if it defers from others here because there is only one UntilThen who will soon become The End.
This is my recommendation:-
Glenn Super 9 OTL amplifier. Here is a picture.
Configuration:-
- 6 x 6BL7 or 2 / 4 x 6as7 or 2 x 6336 as power tubes
- 2 x L63 / 6J5 / 6C5 / 12J5
- 6.3 or 12.6 volts switch
- Tube rectifier
- 5998 boost switch - FORGET ABOUT THIS. 5998 will still sound good without it and you'll save $100.
- Lundahl transformer
- Jupiters caps
- Gold Point 47 steps attenuator
- The first single socket is for your tube rectifier.
- The next 2 sockets are for your 2 x L63 or 6J5 or 6C5 or 12J5 drivers.
- The last 6 sockets are for your 6 x 6BX7 or 6BL7 power tubes. Or you can use 2 x 6as7g or 6080 as power tubes. Or you can use 2 x Cetron 6336b as power tubes.
Final approval by Glenn because I don't know if the tube rectifier in that front and centre position is doable ? If it is, then this is the GOTL that I would want if I have to order again because it would be BEAUTIFUL. More beautiful than Mona Lisa.
Cheers
UT
PS: This configuration will use cheap drivers and equally cheap power tubes too.
For a start,
Get a pair of GEC L63
https://www.ebay.com.au/itm/L63-CV1...m48a5d41812:g:BK8AAOSwH7ZdeoEt&frcectupt=true
Get a pair of power tubes.
https://www.ebay.com.au/itm/MATCHED...m1cc88ded27:g:bJwAAOSw3NpcVElH&frcectupt=true
Ask Glenn to help you to get 6 x 6BX7 or 6BL7
Ask Glenn to supply you with one tube rectifier to start off with.
Lastly, after you get your amp, ask me or the others here any questions on what other tubes to get but go slow and just enjoy the music ... and the babies. Being a Dad, I know what it's like. You may have to share your headphones with the babies.
Lastly, finally and definitely, wait patiently for your GOTL. Good luck.
