Good to know. My pha-1a is coming from Japan.
The only reason I have not bought the Oppo HA-2 was a connectivity issue with my A15 since it requires a special sony data cable + one more usb cable/adapter - too complicated...
I hope that the pha-1a can give me what I want. Let's see
I also have looked at the size of the HA-2 along with the connection to the A17 and I wonder if the added cable cost and carrying them around is worth it. I am leaning towards the Pha-1 for that reason. I hope that there is very little real world difference in the sound between the two units.
Just looking at the PHA-1A and comparing to my PHA-1:
PHA-1 has more power (170 mW @ 10% into 8 ohms; 26 mW @ 10% into 300 ohms);
PHA-1 has the flat top and rails that let you put it flush with an iPhone;
PHA-1 does the high-resolution DAC up to 96 K / 24 bits; the PHA-1A can go up to 192 K / 24 bits;
PHA-1 states a battery life up to 5 hrs (using both DAC and amp); PHA-1A ups that to 6 hours;
PHA-1 I think costs a bit more when/if you find it new.
I've just started using my PHA-1 as a DAC/amp for my Sennheiser HD 800s. Sounds like heresy, I know, but I REALLY wanted to start carrying my HD 800s around with me and this was all i really had in my hand. I was looking for a headphone good in both treble and subbass, had looked at the HiFiMAN HE-500 (good bass but less treble clarity) and HE-560 (its similarity in sound to my HD 800 is what made me think of my HD 800 as the solution to my problem). I use it on Hi gain and have head-vibrating bass at 60% volume setting on the PHA-1.
I did a A/B comparison using my HD 800 on both the Sony PHA-1 and my Sennheiser HDVD 800 DAC/amp, my reference for what is best for the HD 800. Really REALLY close... the only difference was not in spectrum but in sound stage - the HDVD 800 still gave better soundstage, even including a vertical position in the imaging of sources.
Hey thanks; actually the mods don`t allow people to post their ads in the discussion threads, otherwise I would have.
Somebody should grab this beauty - it`s new !
I am giving my first listen to the PHA-1A. I have yet to receive my NWZ-A17. In the meantime I have used an inexpensive 4" Monoprice 30 pin Apple to USB connector to hook it up to my faithful iPod Classic which holds some of my extensive ALAC library. I still prefer my old school ER-4S headphones over anything else that I have heard and I am not a high volume bass head so I will not be able to tell you how well your new tech headphones will work with this unit. I prefer an amp that delivers detail and is a pleasure to listen to without excessive gain. My initial impression is that for me and the edgy R&B tinged jazz that I listen to, this works. I will have to listen for a while to better tell how much more I might I like the sound but so far, for my needs, not bad.
