The only potential issue may be that the ceramic tweeter touches your ear. It is mounted at an angle, out in front of the main driver (imagine a small ‘bump’ on top of the main driver). It may or may not touch your ear. If it does, you can always turn the headphones around 180 degrees, which will make the tweeters angle the opposite direction (fitting in the center of the ear where there is lots of space).
It’s kind of hard to explain in writing. Once you get them just try them and see. As you mentioned, your ears are different than mine so it will likely fit different.
They’re great headphones, and I’m sure you’ll like them
