Ike1985
- Oct 22, 2014
Hmm..this apex tech seems to be just a mesh screen and a vent port, instead of a membrane in ADEL. Vitally's video didn't go into how it work to reduce pneumatic pressure. In ADEL, isn't it's the membrane movement that absorbs the pressure? Venting would relief the pressure too, but I don't imagine by much
. Look like the partnership went south, unfortunate.
I'm sure other companies are eager to utilize ADEL and probably very soon we'plan see them using it. Apex looks like it's just a mesh screen. Cutting a hole in the back of the CIEM and putting a mesh screen in would do the exact same thing as an APEX screen. A membrane would largely preserve the sound sig where as a screened hole should drop the much of the bass. If they're claiming 20db of isolation they must also have a membrane, I don't see how you can get 20db of isolation from a vented mesh screen.
