burpingboy
- Jun 15, 2014
Are you guys seeing what I am seeing? There is no reference to ADEL anymore on 64Audio's website. They have replaced it with something similar and are calling it APEX technology. No ADEL modules for sale in their accessories section either. Also, under the 'Technology' menu, they now have something called the 'Tia'.
Yes it seems like 64Audio is removing all references to ADEL and Asius Technologies and the original S1 and B1 modules, while introducing their new M20 module with -20db isolation, which is even higher than the S1's -18db. Probably the exclusive licencing for ADEL technology has lapsed, but i'm not sure.
I'm more concerned about my order which i confirmed last week via my local distributor, the ear molds are probably still on the way there. My order was for A12 with B1 modules, but i wonder if i would be given M20 modules instead. I wonder how different or similar the M20 modules would be to current S1, B1, G1 and MAMs...
Based on M20's isolation of -20db, it seems to suggest that it would be more similar to the S1 (-18db) than G1 or B1 (-10db). So far S1 reviews seems to suggest that it is veiled, bassy, congested, which is why i opted for B1s. Or is the higher isolation value due to the new placement of the air vent at the side of the module.
I'm bent on getting the MAMs separately, but more information from 64 Audio and Asius will be helpful.
