trybeingarun
Is LME49990 compatible with the new HPA-3U (apparently stock is LME49860)? I know nothing about op-amps, but am wondering if it's worth taking a shot.
The LME49990 is working great at the moment thanks.
I'm thinking of whether to buy some HD598 or at least test them. I've heard it can be more suitable for gaming and watching movies as they have a better soundstage. (I've been using the HD650 for everything on the PC so far)
Is the RCA out around the same as the headphone out? Does the volume control on the amp control the RCA out too? I'm thinking of getting a female 3.5mm to RCA for the HD598 to connect to the RCA out just out of convenience. Or would it just be best to swap headphones on the headphone connection?
Yeah it's the HPA-1.
Okay yeah I'll just swap on the headphone output. Thanks.
I have just noticed the Massdrop Senn PC37X. I don't think it's worth it now though as it's a long waiting list. I just missed a drop on it so the next drop won't be around until July. It's just as well though as the build quality is a bit lower the HD598 plus I already have a mic setup anyways. (Samson go mic attached to a flexible arm phone holder)
Edit: Another thought. What are the K702 like compared to the HD598s? I have heard the K702 is quite good for gaming.
I have K7XX and hd598s. I don't play games but I use them with movies and songs. To me K7XX sounds much better than HD598se in terms of definition & overall sound quality. To me k7xx is an obvious pick. If K702 is anywhere close to K7xx it's better to pick K702
Are the K7XXs just as comfortable as the hd598s? I know the hd598s will be comfortable seeing as I have no problems with the HD650 but I have heard before that the K702s can be hit and miss on comfort for some, especially for long sessions. But then again the K7XX has better ear foam so I guess that can make a difference.
K7xx earcups are huge & but a tiny bit shallow than hd598 so the top of my ear brushes against the driver, just barely though. To me both are equally comfortable and I slightly prefer k7xx over hd598. If you also have hd650 then you should definitely look into k7xx as they have different sound signatures. HD598 & 650 sound similar and you would probably never end up using 598s that much.
Now that everyone's taken his 49990 pill, get ready to roll power cables oh yes......lipstick on a pig yadayada
