Lyssky
Album Advice:
Whyzdom - From the Brink of Infinity
What a production! And Caldera doubles the experience!
Having the Envy, the Atrium Open is the one ZMF I prefer on my OTL. The closed version does better on the Envy but it’s 50-50.
Got the TC and Caldera at the same time about a year ago. TC is long gone. Caldera is quite different but ultimately more my preferred sound signature especially with female vocals, which are too recessed to me on the TC. The TC is still amazing but with the lack of comfort and weird fit that requires specific placement to get the same sound each time, I just gave up on it. If you see a Caldera you really want, go for it!
On stock lamb pads, I only listen with +8dB @90Hz,Q=0.7, and I personally find the Caldera takes it very well, with great authority. With lamb thick pads, I have to reduce that down to +4-6dB. Given my HRTF, I have to add +11dB @100Hz,Q=0.69 to reach the same level of bass on my LCD-X. YMMV. I also find the Caldera does a much better job with slam than the LCD-X.How does the caldera take a good bass shelf (probably around 8db)?
I use Mojo 2 DSP. My opinion is that Caldera can be EQed as well as Audeze. It is not fair to compare LCD-XC to Caldera and mine is a 2020 version so it is the old Audeze bass but as a general idea I think LCD-XC bass is more overarching (don't know if it's the correct word) but less precise (obviously). Caldera bass is very well nuanced, emotional and plays its own game.Finally pulled the trigger and bought a caldera and so, my weeks of suffering waiting for its arrival have begun.
I just have a couple of questions, How does the caldera take a good bass shelf (probably around 8db)? Is it as good as Audeze drivers in that regard?
I will try to get rid of my Verite closed if I can just add some extra bass to the caldera for EDM. Also, how is the slam compared to the VC? Does the VC has more slam just because its a closed back? How does the soundstage compare to the VC? one of the aspects I love about it is the big soundstage it has for a closed back.
Cables wont really change the sound much/at all. I would consider pad rolling or EQ for greater bang for buck. A lot of cable talk is sadly snake oil. All these people also swore they could notice a difference. It happens because your brain is expecting it, not because there is one!
But if we must talk cables, I have been curious about getting gravedigger cables. They use a plastic polymer coating that doesnt conduct as much mechanical noise as the fabric sleeving man brands use. The fabric/nylon tends to conduct noise when it rubs against things. In my case my hoodie when im moving around my cold house
I use lambskin thick pads w/my Caldera and wouldn't think of EQing this headphone in search of more bass. What I'm getting is perfect, also perfectly proportionate to what the Caldera is doing in all the other frequencies.I use Mojo 2 DSP. My opinion is that Caldera can be EQed as well as Audeze. It is not fair to compare LCD-XC to Caldera and mine is a 2020 version so it is the old Audeze bass but as a general idea I think LCD-XC bass is more overarching (don't know if it's the correct word) but less precise (obviously). Caldera bass is very well nuanced, emotional and plays its own game.
I need to highlight Caldera's bass a bit more when using Mojo 2. Maybe this is not necessary with other types of dacs/more powerful amps. Don't have any other so can't try. And I too love bass. So much so that I listen to some songs only for the bass feel.I use lambskin thick pads w/my Caldera and wouldn't think of EQing this headphone in search of more bass. What I'm getting is perfect, also perfectly proportionate to what the Caldera is doing in all the other frequencies.
The bass I hear with Caldera is not simply deep and hard hitting--it's tonally accurate and textured in way that sounds pretty close to the real thing. What more can one ask of headphone bass?
FWIW, I love bass (from headphones, speakers, and live music), but I always want it be excellent in the context of everything else I'm hearing, musically...
That's an interesting comment. It got me thinking:Maybe this is not necessary with other types of dacs/more powerful amps.
Does the OG D8K have this peak as well? I know the Pro is supposed to be brighter than the OG.D8K Pro was so *close* to me but the 7kHz peak is a deal breaker because it makes vocal sound sibilant.
Not to my ears it didn't. It's a lovely, smooth, slightly warm headphone with even but slightly rolled off highs.Does the OG D8K have this peak as well?
No, the warranty isn’t transferable on any ZMFs.is the warranty transferable on the caldera?
