Deleeh
Hello,
I agree with you that we do not misunderstand each other and I also share the intentions.
I have tried a few things over the days with interesting results.
For me, it's always a matter of first understanding the headphones, which always takes a few hours of listening.
That was also the case with the Audeze lcd 2C.
With time you get to know the strengths and weaknesses of the headphones.
It is also clear to me that one should never be prejudiced if a burn in lasts longer hours.
I've already got that far behind me.
I've done the 200 hours and it's already made a difference compared to when I unpacked the headphones and let them play.
Even with the auteur pads it has definitely improved after 200 hours.
In the meantime, I have also found a pair of tubes that works at the moment.
Which is already good.
I also tried out a silver cable against a copper cable, where I also noticed a few subtle things.
I'll have another go at it, even though I've already made up my mind.
I have also played a bit with the dac.
And I was able to gather a few insights there as well.
What I can say is that it has improved a bit more than subtle things with Day Y but also other areas come across less accurate and less good that were better before as with Dac X.
So also there you can and still let the auteur tune to your needs besides a tube amp with different tubes.
The fact is that the first Dac is a standalone at $300 and the other is a Dac/amp at just under $700.
And both play on a similar level with cor and disadvantages.
Looking at my equipment, the Dac is now the weakest link in the chain next to the Feliks Euforia and Auteur headphones.
I have to admit that.
With the Lcd 2c it was still a good match, but unfortunately not any more.
That's why I think that with the Dac I can get something out of it that eliminates the weak areas where there is a deficit.
It's certainly not too much, roughly speaking, but it's essential.
Of course it won't increase the bass range and other areas and the like, but it will make them more accurate.
The auteur is definitely good without talking again.
But in my case it has not yet reached where it needs to be I think.
Tube rolls will only help minimally to make it better and there will still be a price to pay.
I like it a lot and it does a lot better than the Lcd2C.
