Amazing looking headphones, and nice photos!@audio duck,yes that is the auteur I got in the profile picture.
I'm attaching a photo, I just noticed that I haven't inserted any.
Thanks for the compliment .
I am not a fan of Eq.
I think headphones should be able to deliver what the listener expects.
I put up with the filters from the dacs and sometimes they can be helpful.
I had the same problem when I got the Euforia with Lcd 2C and it was really due to the stock tubes where the bass was already anaemic.
It's not that bad with the Auteur.
What comes to mind is that maybe I need to get used to the sound a bit more.
Some people have reported that they had a hard time at the beginning and then all of a sudden it worked.
Of the 115 hours of burn that it has been through, I have only listened to it for maybe 15 hours.
That is perhaps still too little.
Maybe there is still something that could be done with one or the other tube.
Maybe the dac has become the weakest link in the chain, I thought of that.
With the Lcd2C it might have been fine, but now with the Auteur on the Euforia it's something else again.
With the Singxer Sda 2C, it could be undersized in certain areas, I would imagine.
But I also agree that the bass is very natural.
Sometimes it could be a bit more, I think.
With other music genres it fits perfectly, even R&B it does its job really well most of the time and has already brought great moments of happiness.
Next week it will have its first 200 hours on it and then I'll see how it goes.
Thank you for your support,.
It's a bummer that they're not clicking for you. Another idea would be to try them on a decent Solid State amp if you have access.
I love the tube sound myself, but I've found it's more of a challenge to get bass slam with tubes. It's definitely possible, but I think it's easier with SS. Going with SS for rap and similar music could be a workable solution, of course YMMV.
(Edit: keep in mind I'm not that familiar with the Feliks amps, so others with more experience there might be more helpful)
Best of luck...
