Recently parcel to UK arrive super fast from aliexpress I wanted to use the Tempotec as a transport and zishan as a dac. I f I am not mistaken U1 has the same dac chip as fiio m11. Currently have it hooked to my pc paired with fiio fh1s and all seems fine, really enjoying the sounds I hear
Recieved mine today. Did not have time to play with it, but tried to connect it to tempotec and it did not work will try to play with settings tomorrow when I will have time.
Wait, what tempotec device you're trying to use as a transport to the U1? Is it tempotec V1? You connected the digital out to the correct input (USB DAC)?
That's not good. I mean if it work for tempotec V1, it'll be a great combo. Let me ask to my source.
I have tempotec v1a, maybe that is why it is not working. Yes I did connect it to the correct port using cable (usb-c to usb-c) that was included with the zishan. Or it might be the faulty cable, but at the moment, I do not have another cable to test it
Tried to connect it to my phone today, and... Nothing Seems it is a t*rd of a device, or it is definitely crapy cable they have included in the package, because it connects to pc with no problem.
I have tried playing with these settings , but I was automatically dropped back to charge external device option or something similar. I am at work at the moment, so I will have another look back at home
I had time to check the zishan more. So the included short Usb-C to Usb-c cable is fine, because if I connect with it to a pc all is working fine, but the phone is a different story. No mater what option I select, it automatically dropps me to charge external device only mode. I can hear the U1 making a clicking sound, when connected to a phone, but nothing else is happening. So U1 is not a plug and play device for my phone.
A bit more information on T*rd U1 I have tried it with an LG G6 ant could not connect it to it as well, so I will wait for someone else to tell the stories of their experiences. I have written to the seller on the aliexpress and asked him, maybe he knows a solution to this problem, but I do not have my hopes high on this one.
I hope it can work for your G7. Otherwise you're going to make it sit with your PC based on what BubisUK reported. Fingers crossed it'll work with phones.
It doesn't make sense to me that the device doesn't work on phones. It is possibly a bug that can be fixed by firmware update. Another possible explanation is that it will definitely work only on a few phones. Let's wait...
