The ZiShan U1 it going to replace my old Fiio X3 and the Cypher Labs Piccolo. I had no issues to connect the U1 to my Xiaomi 10 and also my old Huawei Mate8 with an oder Mini-USB, I used a OTG-Cable as adapter.
The Huawei does not accept all players it runs on Android 8 but on the Xiaomi with Android 10 no issues at all, it will immediately recognized as USB-Sound Device. I successfully tested "USB Audio Player Pro" and "HiByMusic" Player on the Xiaomi, on the Huawei only "HiByMusic" is working.
I also opened the U1, the version is still the same as on the promotion pictures. The PCB is marked with U1_7. The Battery was fixed using a sticky double tape which left a lot marks on the components after removing.
I like the sound, compared to the X3, which is of course not a reference but so far my best portable DAC. The is sound more detailed - more crispy and the bass has more definition. At the beginning I felt it is a litte too analytic but I get used to it now and can hear more details compared to the X3.
It has two outputs High and Low, I use the High output for my B&O H6, the volume is unfortunately opposite operation to what is "normal" right turn is to lower the volume. I also would like to see a line out which it does not have. There are relays working inside making a noticeably noise when plug and unplug the U1, also when start and stop playing music.
It was a great buy and I am very satisfied. The cost here in China is 238 RMB which is about 34US$, as I am living in the same city as the manufacturer it only took 1 day to arrive. I think its amazing what can be done for this little money.
I am not related to the manufacturer, I am German living and working in China.
Some Pictures - Inside:
My actual config - Xiaomi 10 and B&O H6
Also tried the old Huawei Mate8:
My old gear: Fiio X3 and Cypher Labs Piccolo (prototype).
