I recently bought both the G1a and G2a. I only have about 40 hours on the G1A's and about 20 hours on the G2a's, with the time consisting of roughly 50% pink noise burn-in and 50% music listening for both. Up till this point, my favorite "headphones" have been the PK2's, as they are enjoyable with all kinds of music. However, I wanted to "upgrade" to something with more range (low-end) and the G series from Yuin intrigued me.
As far as my equipment:
Portable player: Sony NWZ-S616F
Portable amp/DAC: NuForce Icon Mobile
Notebook: Realtek HD audio (good SQ, no problem powering either)
Initial impressions (no burn-in):
G1a: fairly flat response, lacking low-end, some of the vocals seem "distant", resolution/sensitivity isn't there yet.
G2a: high-end is peaky and a little harsh, lacking some low-end but more present than the G1a's, resolution/sensitivity isn't there yet.
Half burn-in (mainly from music listening):
G1a: response is still flat, low-end is beginning to fill in, vocals still a little distant at times, a little more resolution, but it's still lacking.
G2a: still has an exaggerated high-end, low-end is filling in, a little more resolution.
Current impressions:
Then I decided to run both through pink noise, the G2a's got about 11 hours, and the G1a's got around 24 hours.
G1a: response is flat, low-end has filled in well, vocals no longer have the "distant" feeling, the resolution is beginning to surprise me
G2a: response has smoothed out some, high-end is still exaggerated but not as harsh as before, mid-bass and low-end have filled in well. Much like the G1a's the resolution/sensitivity is showing itself.
Both have shown continuous improvements, so more burn-in will be helpful. Others have commented on them needing quite a bit more!
Right now, I like the G1a's better. Their flatter response makes them easier to listen to, especially with heavy metal, and you can hear more in the music because nothing is overpowering. The G2a's have a very similar sound, but the upper-end is a bit more exaggerated, which makes it a little more "in-your-face" (like the PK2's). The G2a's have a tiny bit more bass than the G1a's, but both do very well.
Coming from the PK2's, I definitely like the G2a's. They provide a lot of what made the PK2's "fun", but filled in the missing parts. MP3 players have no problem powering them. If you're deciding between the PK2's or G2a's, I'd suggest going with the G2a's. They're a great value for $50! The G1a's step it up a bit, but at $150, they are by no means the value of the G2a. Plus needing a good portable amp throws another $100 (or more) into the equation. However, I needed the USB DAC for listening at work, and couldn't pass up trying the G1a's! So far, I'm liking them a lot
My brother has some good phones I'd like to compare the G1a's to, specifically the Phonak PFE's, OK1's, and RE1's (IIRC). I've actually listened to each a little bit in the past, but not enough to make comparisons.
