Arvan
- Jun 14, 2006
Freaking love Xduoo for working with this product!
heh... was really hoping v7 would add it.If they add the option to shuffle everything on the card I will definitely get one. I nearly always listen on random play, very rarely listen to a complete album. When this gets added (I hope it does) I will buy.
Hello all, so the X2 suddenly froze. It has turned off after leaving it frozen. I was planning to reset it but forgot to. Now it doesn't turn on. Any ideas?
Try charging it for an hour or so, then reset it and turn it on.
Resetting is as simply as pressing the reset button? Even if it's not on?
Yes, just press the reset button with a pin or something. It should reset the whole thing.
Sorry, this didn't work.
It does have some charge to it, correct?....
I plugged it in although there was no indication that it was charging i.e. the screen isn't on and there are no signs that it's charging when I plug it in.
Tried resetting and charging at the same time?
press power on and reset a few times. Connect battery and do the same.
Or measure the voltage of the battery, maybe this is the problem.
and this:
I can't remove the battery at the moment because I don't have a screwdriver that fits the screw. I'll probably try to find one tomorrow.
Sorry, I don't have the knowledge nor equipment to do this.![]()
