xDuoo X2 - small lossless player with microSD and OLED!
Jul 5, 2015 at 12:49 AM Post #902 of 2,091
had the same issue with my unit (not turning on), returned it to get repaired
Came back with a scratched screen. Heh
Yeah, same with me except I got a brand new unit that was the first that came of the conveyor belt for the 2nd revision X2.
Jul 5, 2015 at 3:29 AM Post #906 of 2,091
Hmmz...
I think you got yours back earlier than me? I only got mine back about 3 w ago.
Did you go directly via xduoo or penon? Xduoo referred me to the dealer(penon) who I got it from in tyre first place
I got mine back maybe over a month ago. Mine went through Penon, but they went through xDuoo directly. I think it was a somewhat common issue on the first revision. The second revision has some better components, so works flawlessly.
Jul 5, 2015 at 3:38 PM Post #908 of 2,091
  Anyone tried the klipsch image 1 with this player? Is it possible it will tone down the bass or even increase the problem?
For what it´s worth i have tried the Image II and.. The bass is just so damn over the top in this headphone! If they tuned it with half the bass it should be a good headphone! ( learn something from the AKG y50 ) Anyways, there is no user EQ so you are stuck with presets. I would not rely to much on the players EQ to tune a bad sounding headphone :) ( to my ears anyways, no hard feelings )
Jul 6, 2015 at 8:44 AM Post #910 of 2,091
Not sure if y'all already saw the new X3, probably available at the end of august.
Specs:
Power: 1500MAH 3.7V lithium polymer battery processor: the king is smart chip JZ4760B
Operating System: LINUX
DAC chip: CS4398
Amplifier chip: one per channel rail-to-rail high-efficiency amplifier chip
Card support: maximum support two 128G TF / Micro SD Card
Output power: 250mW (32Ω load)
Line out Output level: 1.5Vrms
Support music format:
DSD: DSD64
APE: 24bit / 192khz
FLAC: 24bit / 192khz
WAV: 24bit / 192khz
APPLE Lossless: 24bit / 192khz
CUE
WMA, MPE, AAC, ALAC, OGG
Frequency response: 20Hz ~ 20KHz (ą 0.5dB)
Gain: + 6dB
Distortion: 0.001% (1KHz)
SNR: 110dB
Adapter Headphone Impedance: 8Ω ~ 300Ω
Life time:> 10H
Charging time: <2H
Volume: 105.5 * 45 * 14mm
Weight: 100g
Color: black, white
Price will sit around $100
Any thoughts?
Jul 6, 2015 at 9:08 AM Post #911 of 2,091
Specs:
DAC chip: CS4398
DSD: DSD64
APE: 24bit / 192khz
WAV: 24bit / 192khz
CUE
Gain: + 6dB
SNR: 110dB
Life time:> 10H
Charging time: <2H
Weight: 100g
Color: black, white
Any thoughts?
post #804
Jul 6, 2015 at 9:13 AM Post #912 of 2,091
Specs:
DAC chip: CS4398
DSD: DSD64
APE: 24bit / 192khz
WAV: 24bit / 192khz
CUE
Gain: + 6dB
SNR: 110dB
Life time:> 10H
Charging time: <2H
Weight: 100g
Color: black, white
Any thoughts?
Well, there's nothing to think much against it's tech specs given it's price tag.....
Jul 6, 2015 at 9:29 AM Post #913 of 2,091
I went for the X2 as an attempt to replace a sansa clip(small not powerful stuff), so the X3 would really defeat that purpose with the bigger size and the apparently massive output.
250mw into 32ohm is certainly something, it might be one of the cheapest pretty powerful DAP available, I would personally need to see a little more specs (into 16 and 300ohm and know if it's @1%THD or pure max output, and of course noise^_^), but that brand seems to be promising.
Jul 6, 2015 at 11:10 AM Post #915 of 2,091
  To much breath for you @castleofargh ^^
yup, but it's not like my other DAPs are noiseless
.  the FIIO X1 is the cleanest I have now.
secret french conspiracy talk that nobody else can see: "breath" n'a pas ce sense en anglais, noise, hiss, hum ... mais pas breath).
