Inszy
- Jan 1, 2014
there is a bightness option(well, backlight but yea) but i'm not sure it actually does anything :|
There you can set the time after which screen goes blank.
1) Will the clip+/sport, combined with fiio e6 amp, be same or better than the x2 in terms of sound?
2) What does the clip lack when compared to x2 on its own? Is it less detailed, or other?
3) If I use a clip by itself with, say, a 22 ohm iem @ 105 sensitivity, how much worse is it compared to x2?
4) Does anyone have experience with cowon iAudio i9, 9+, or 10 for comparison
Thanks for your replies guys!
So the x2 handily beats clip in SQ, and it seems fairly reliable.
Has anyone encountered freezes or any thing to suggest this device is unreliable? I don't mean to be annoying, just want a guarantee that I won't have to do through another cowon experience and send this thing back 3 times for RMA D;
i would suggest people avoid trying the beta update for now.
my x2 shut off on the train to work with about 3/4 battery left.
I though - well, I'll just reboot it with a paperclip when I get home
but ... it just sits there clicking relays like on startup except when connected to a charger
nothing happens and doesn't boot.
any buttons without power connected = no response (including reset)
I've contacted xduoo support to investigate. Not sure if it is related to the beta firmware update but if you want to chose between no flac and possibly RMAA - avoid installing it until the issue is confirmed by support for me
This is exactly what happened to mine. Not sure what FW I was on but it just clicks but it's completely dead.
I wasn't going to say anything up until now.
The last 3 days, (and especially the last 24 hours) my unit has been shutting down and resetting.
First time it just froze and reset itself.
Then it froze and wouldn't turn back on for 20 minutes.
Another time it skipped the music and reset again back to the start.
I had another error half way through a song saying 'format error"
And just 5 minutes ago I got half way through a song and it turned off (won't turn back on again)
I tried removing all tags from my card but the problem remains and the interval between shutdowns is getting much shorter. Up until now I had no problems with my unit since it arrived but the last 3 days it's been nothing but an annoyance and I'm not one to usually complain about an occasional freeze. I'm practically done with this unit and its becoming more trouble than its worth.
I guess I will send it back for a replacement but I cannot recommend this player anymore, there's something wrong with them from the reports we're getting. Something wrong with the circuitry or something burning out slowly. Quite a few cases now, and its probably best to avoid it.
Did you also install the update? I wonder if it could be related to it? I personally can't comment on such issues as I haven't been using mine that much. Probably an hour a day and since the update I've used it for just half an hour. On the other hand, before the update I piled on a few hundred hours on it while burning some iems and didn't notice issues aside from inconsistent battery life, which might point out to a problem with the battery used.
Its kind of bitter sweet but I'm glad I'm not the only one with this issue. I might ask them for a refund and just save up for the FiiO X1 instead.
