xDuoo X2 - small lossless player with microSD and OLED!
Feb 10, 2015 at 3:06 AM Post #406 of 2,091
I didn't install the update.
Its has been a while (many days) since I charged it, although it still said 3/4 bars I'm giving it charge now to see if it runs again like normal.
I will report back and let you guys know. Mine had been used quite a lot since it arrived smoothly, but the last few days its been playing up.
Yes, its becoming a little too regular. Let's see if a charge fixes my unit as its a little different, not completely dead, just switches off etc....
Well, as I said I've been using it for burn-in a lot and pretty much charging it daily or every other day and the battery indicator for one is completely off. Often times standing at 3 bars for the most of the battery life and often times catching you off-guard so for outside use I started topping it off like I do with my C3 when it reaches 2 bars as the c3 is also known to last about couple of hours when the indicator shows the battery is half full.
Feb 10, 2015 at 3:11 AM Post #407 of 2,091
Yup, I agree.
Have you noticed it charges very quickly? Mines done in about 20-30 minutes.
And...its been working again for almost 30 minutes which is a good sign. But let me report again after a few hours. Maybe my symptoms were a low battery.
Feb 10, 2015 at 3:19 AM Post #408 of 2,091
Yup, I agree.
Yeah, charges relatively quickly. Haven't tried it from a USB but with the wall charger for my phone it probably takes about 50 minutes or less for the completely drained battery to fully charge.
Feb 10, 2015 at 3:26 AM Post #409 of 2,091
Well, I don't want to speak to soon but my unit hasn't stopped working yet since the charge. (it would have by now)
When you mentioned the inconsistent battery life / meter then put my thoughts about the shutdowns getting worse and worse / shorter and shorter it kind of rang alarm bells. Now, add that up with a fresh charge and stopped emitting the problems...
Let me confirm though after a couple of days to clear this up (be nice if it was just the battery)
What also confused me is I have seen my battery meter drop to 2/4 bars a few times so at 3/4 I thought I was fine.
Will report back.
Feb 10, 2015 at 4:09 AM Post #410 of 2,091
All modern batteries can be random the first couple of charges. Most common is smartphones where the battery does not "settle" for up to like 5 full cycles sometimes. Let´s just hope it´s linked to that. However, dodgy battery indicators is rather common on devices like this. My ipod has the same issue, so did one of the clips that i owned.
My player is still going strong, let´s just hope it stays that way :)
For those who have opened the device, can you replace the battery?
Feb 10, 2015 at 6:36 AM Post #411 of 2,091
Looks like I'm saving up for the Fiio X1 now... I was looking forward to trying the X2 out, but I don't have time to be dealing with defective units if that's a possibility here...oh well.
Feb 10, 2015 at 9:28 AM Post #412 of 2,091
HiFinage has organized a review tour of the xDuoo X2 in India. I'm first in line and should receive it in a few days. Let's see if it can dethrone my mighty clip.
https://www.facebook.com/events/696328137141739/?ref=51&source=1
Feb 10, 2015 at 8:48 PM Post #414 of 2,091
Dang....was really looking forward to trying this
Fiio x1 it is!
Feb 11, 2015 at 4:48 AM Post #417 of 2,091
I can report since charging my unit it hasn't exhibited any further problems. I would like to assume after testing the last 24 hours my case was simply signs of a low battery.
I've edited the original post last page to reflect this for future readers.
Feb 11, 2015 at 11:19 AM Post #419 of 2,091
Chosen x2 + Fidelio x2 over my desktop setup of Schiit Magni 2 + Schiit Modi 2 uber + QLS Qa360..
And I am not joking :)
Wow, that's quite a statement. I'd take it that the X2's pairs very well together then.....
Anyone compared the Fiio X3 and the X2?
Feb 11, 2015 at 11:26 AM Post #420 of 2,091
X2 pairs well with any dark sounding HP as its bright sounding. The only drawback I experience is in the "authority" on lows being pretty low at X2 compared to that amp and dac and desktop dap setup.
