I have a question to those of you out there with a TA-20. I just got myself a pair of HifiMan Edition XS, and they replaced my Sundaras on the TA-20 as my "planar setup".
However, i noticed now for the first time that microphonics is REAL real. Even turning the volume wheel makes audible noise from the driver in the headphones. And tapping lightly on the chassis or tubes is just a serious no-go. Is this normal? I have never ever had any issues of this sort nearly this evident before.
Obviously this issue came into my life alongside the Edition XS's, but still. I didn't think that they would be that much more sensitive than any other headphone i've ever tried out on the TA-20.
Any experiences and or opinions on the matter out there?
Microphonics are conducted and exacerbated by stiff headphone cables, and Hifiman's Classic "Medical tubing" sheathed cables are one of them
If your tubes are microphonic you want to find/use soft jacketed cables that won't conduct any vibrations, stiff coverings that can conduct the vibrations will make more noise when moving them around.
I replaced my Hifiman cables with GUCraftsman Silver plated cables for the Ananda and HE6SE V2, and also for my HD660S, HD598cs headphones:
https://www.aliexpress.com/store/3879013
https://hifigo.com/collections/gucraftsman
For my IEM's I use KB Ear 16 Core Silver and 4 core 99% Pure Silver cables.
https://hifigo.com/collections/kbear
https://hifigo.com/products/kb-ear-...th-metal-2pin-mmcx-qdc?variant=31605483667505
https://hifigo.com/products/kbear-4...-with-2pin-qdc-mmc-tfz?variant=32250235322417
That said, most of my tubes aren't microphonic. I've been told that E180CC Pinched Waste tubes are *all* microphonic, but these weren't - at least on my TA-20 with soft cables:
NOS NIB PHILIPS HOLLAND PINCHED WAIST D FOIL GETTER E180CC 7062 12AT7 E81CC
https://www.ebay.com/itm/185162828671
I might have been lucky with those though... I just tapped on the top of both of them in my TA-20 and I had to hit the top of the tube pretty hard to hear anything.
I'm listening with my Sennheiser HD660S stock cable, which is a nice thick rubber like covering for the 6.35mm to 3.5mm converter, and even plugging in the Zip Cord cable that the long length of the cable is made from - still soft and rubber like covering.
BTW, that pair of PHILIPS HOLLAND PINCHED WAIST D FOIL GETTER E180CC sound phenominal, I mean it was so timely getting them along with this latest selection of tubes for the TA-26, as it put the TA-20 back in the "competition", they provide the most space and air of any previous tubes.
With these the TA-20 is "keeping up" with the TA-26
Give me a day or two and I'll run through my tubes / cables - including the stock Hifiman cables - to see which are making noisy from physical movement / tapping.
Which make/model of tube is doing this? Is it both tubes? Do you have a soft adapter extension you could use to interrupt the vibrations?
I haven't felt the need to get any, but there are "tube rings" made for each tube type, heavy metal and rubber, I don't recall where I saw them last, but those are used to dampen oscillations from bad microphonic tubes.
You could also try putting a soft cable converter like mine is between the headphone cable and amp...
