@Audiophile PTThere exists such info out there - I dug it up when I started looking for 12xx7 headphone amps - before I decided on the Xduoo TA-20 and that info helped me decide on the Xduoo TA-20. It'll take me a little while to pull it together again, but I'll drop some as I find it
I'm sure there are a bunch of others out there with a TA-20 that would be able to contribute their favorites
On this note; I just picked up my Philips Miniwatt E180CC SQ tubes (https://www.ebay.com/itm/133642391945?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649) 12AT7 equivalents to be used in my TA-20.
First impression (probably no surprise here..) is that i could have just not bothered buying any of the other tubes i have for this amp.
I would have saved (quite a bit) of money just buying these in the first place. So to anyone looking for the best starting point although somewhat pricey (100$ + - depending), it'll probably save you in the long run if you're the type to "set and forget" tubes, as opposed to a rolling fanatic.
If you're in it for the game, to roll tubes and just have a marry old time doing so, then start with whatever you fancy.
But if you want to spend once, and be happy with the fact that it probably doesn't get much better for a reasonable amount; then these should be it.
Obviously this is my glaringly subjective opinion, and must be understood as such. But to me this is going to be "endgame" for this amp. Simple as that.
Also worth mentioning is that this is paired with Hifiman Sundara balanced in my case, and obviously YMMV as far as your taste in sound signature.
Compared to the TA-26 This is now a in a kind of strange place, as it sounds more detailed and "cleaner", however i guess it can be percieved as bright in comparison. The TA-20 still has that tubey "space, glow and glare" which is so fascinating. I guess the TA-20 with these tubes sound more "high end"?
It's hard to describe really, but it's just a little more dynamic than with any of the other tubes i've tried with it, that includes the Mullard 12AT7's, which are a bargain buy for this amp in my opinion (about 50$ or so) and a great pairing as well.
Again; my opinion/experience with my setup and my points of reference. But i now have quite a few spare pairs of 12AU7's ..
