billyleungkt
Something on my doorstep today
Woohoo!! Merry Christmas guys!!
Well had two different wa5 Le a gen 1 and gen 2. My problem tubes where problem on gen 2 but no problems on gen 1. So something in the design of the amps.Is it normal for the Tung sol 5998 to hiss at no volume, I noticed the 5998 hiss when no music is playing or at low volume, but the hiss doesn't increase when I turn the volume up. When I swap the wa2 stock tube (Jan 6080) back, I didn't notice any hiss at all at lower volume, should I be worried about this hiss?
The 12AT7 / 12AU7 tubes are ‘rewired’ for 6V use via those adapters. Also the filament current (300 mA) is under that of the 6922 / 6DJ8 tube (365 mA). The 12AT7 / 12AU7 + adapters are fine in the WA2.I have a Valhalla 2 along with 12Axx to 6922 adapters, and a stash of 12Axx tubes.
Does the WA2 behave when using these adapters with 12AT7 or 12AU7 tubes? I don't see them listed in the compatibility chart on wooaudio.com
They are all that I use...after going thru so many 6922 types. My favorites:I have a Valhalla 2 along with 12Axx to 6922 adapters, and a stash of 12Axx tubes.
Tube rectification should really help. High high recommendation: RFT EZ81 ‘foil’ getter. If not that, RFT EZ81 ‘halo’ getter. Inexpensive and excellent / unbelievably good. EDIT: Also, try Brimar CV455 KB/FB (Footscray) or RFT ECC81 ‘foil’ getter / ‘halo’ getter with 12A#7 (top) => E88CC (bottom) adapters. Moving off the 6922 / 6DJ8 tube type will yield improvements.hey all. just purchased the Verite Open headphone from ZMF and loving it!!! However, on my Wa2 it sounded kinda , non 3d for lack of better terms. and mids do tends to come forward a little. My wa2 have the following tubes
- tung sol 7236
- siemens e88cc platinum
- rectifier was modified to solid state due to a broken tube, will be changing these rectifier to new tubes.
What can be done to enhance 3d soundstage and reduce forwardness a little. Any recommended rectifier tubes that helps with this. I'm pretty sure the solid state rectifier may have something to do with the lack of 3dness and seperation, and i forgot the sound before the tubes broke (never tested with verite before) . For now I'm thinking either the rft ez80 or the philip miniwatts ez80 as those are easy to get.
Thanks for any helpp.
@jonathan c any good advice on where to find an RFT EZ80 with foil getters? I have a pair from the 50s but they are D getters.Tube rectification should really help. High high recommendation: RFT EZ81 ‘foil’ getter. If not that, RFT EZ81 ‘halo’ getter. Inexpensive and excellent / unbelievably good. EDIT: Also, try Brimar CV455 KB/FB (Footscray) or RFT ECC81 ‘foil’ getter / ‘halo’ getter with 12A#7 (top) => E88CC (bottom) adapters. Moving off the 6922 / 6DJ8 tube type will yield improvements.
The sellers that I have used are (were?) in Russia and in Ukraine. On EBay, I have had excellent items and service from ‘delax777mechanics’ (Ukraine).@jonathan c any good advice on where to find an RFT EZ80 with foil getters? I have a pair from the 50s but they are D getters.
I bought a couple of those and I really like them. They are my main drivers since the CV455 I got from Langrex crapped out after a week (7 days and they still have responded to my email about refund). Any leads on a foil getter EZ80? I've only seen D and halo getters if those.Here's a link for RFT ECC81 foil disc getters. Can't vouch for the seller however.
https://www.ebay.com/itm/234442698371?hash=item3695dfae83:g:~hcAAOSwKP5iG7wC
Here are the adapters you will need to use them in your WA2.
https://pulsetubestore.com/products/12axx-to-ecc88-adapter-plug-play-novib-©-1960s-nos-british-mcmurdo-phenolic-socket-on-top-plus-vibration-reduction-base-9-pin-b9a-noval-not-made-in-china
Nope...but I will say that once I made the move to EZ81's I've never looked back. I'd highly recommend you keep an eye out for the RFT EZ81 foil getters. They show up fairly regularly and aren't usually very expensive. I'm alternating between them and Marconi U709's (which are ridiculously expensive, lol) and the RFT's really hold their own when I compare them.I bought a couple of those and I really like them. They are my main drivers since the CV455 I got from Langrex crapped out after a week (7 days and they still have responded to my email about refund). Any leads on a foil getter EZ80? I've only seen D and halo getters if those.
