I had no chance to listen to wa3 before I got it and I have never listened to wa2 yet. I have bought wa2 without listening and tomorrow (hopefully, when it is delivered) will be the first time I will see wa2.
I have verite open, I really like how they sound with wa3 and decided to go for wa2. I like how OTL amps sound, although It is very subjective. Verite Open are said to sound well with many amps. If it is worth to go for OTL You should decide Yourself.
If You worry about tube prices do not go for these amps... wa3 is easier to deal with in terms of tubes, as it has no rectifier tubes and only need one power tube.
I get tubes mostly on ebay. But the prices are going up and up unfortunately. Power tubes for those amps are not in current production. You only are able to buy old stuff. False tubes are not uncommon unfortunately. If You worry reconsider OTL or try wa3 first, but it is up to You. Without trying OTL You will never know. I am quite sure there is a possiblity to listen to OTL amp in HK.
