Not really for me either but I'm also not that into horses for courses. If everything is right, an accurate IEM will bring what the engineer intended. Of course, everything right is seldom the case and 'enhanced' balanced is preferred by some(many). I think the E-q5 with the right tips can cover it's tracks just enough for a less than stellar source while still being fun, informative, having good bass and being pretty true to the mix. The GR10 has a slightly less mid forward balance and is a bit more informative of subtleties but also more critical of associated files and kit because of it. It has a bit more to offer in the way of textures and space between the notes but can more easily show other deficiencies which can be plenty in portable. If you just plug them into whatever you got, depending on tips, either could be preferred but more can be coaxed out of the Grado. This is going to be the dilemma with all expensive IEMs. Are you actually getting your money's worth with how they're being used or could something less expensive serve you as well or even better. Like the home market, consumers are transducer driven but as they get into the excellent range, other parts of the setup actually become more defining. You always need to ask yourself what the weakest link is and what compromises work for you. I find internet boards very bit perfect and spec driven and there's so much more to good sound.
I think the E-q5 a nice safe purchase for a wide genre. If you want a warmer presentation, Sony hybrids fill them out without robbing too much top as they can with some phones.
Ok thanks "True to the mix" is definitely what I want . I now listen only to Dance Styles of music with it's many Genres.. I'd only consider the GR10's if many reviews agreed they were a higher quality sound than the E-q5's, since the GR10's are considerably more money in the UK than the E-q5's .
It is because of the extreme difference in the reproduction of bass presence in relation to the mids-highs ,on tracks with a more dominant low end ,between the CK10's and other headphones namely HD25's & G2a' that is driving me to fully research the opinions of the E-q5's and any other I.E.M's . Simply so I don't buy the wrong I.E.M .
I listen to a fair share of trance and electronica, but wouldn't call myself an avid fan. But even among these, opinions will differ. AFAIK shigzeo is an avid trance fan and the CK10 are his favorite IEMs.
The way you keep focusing on bass makes me think you should maybe try DD based IEMs. Those MAs have more impact and better texture than the CK10, but it's not a night and day difference. Moreover, all of them roll off steeply below 30Hz, so if you're into rumbling sub-bass you might wanna look elsewhere.
The reason I'm trying to get a idea of the nature of the MAs is because I want the impact and better texture
I'm trying to establish a general consensus of how these MA's produce the bass regions so as to get a idea before spending money.Do the eq-5's have a sufficiently balanced low frequency range relative to the mids and highs,so as to be able to accurately reproduce the
Dance Genres of music.Not only the specific genre of electronica ,which can be very light in the bass regions compared to Tribal /Tech House for example .
But the different tastes that are forming opinions on many boards makes it very difficult to get a decent Idea of what level and true to recording accuracy the E-q5's have .That is why I wanted opinions from people whom are House,Trance,techno music Fans .
The Title asks
EQ-5 ,GR10's or FI-BA-A1's ! Can they produce House,Trance,techno Music
I was hoping that fans of these Genres whom had tested out these I.E.M's could give some valuable information .
Only if rumbling sub-bass is in the original source
30Hz isn't that sub either ! .Maybe that was the issue I had with the CK10's.The "average" 808 kick drum can be anywhere around 46Hz + / - .The essential bass presentation that was missing may of been the Sub of the drum .Add to that the forward nature of the CK10's Highs and you have, relative to
some Dance music, a very unbalanced I.E.M.
Sigh! so maybe I can't as yet have my CK10's Mid-highs and Dynamic driver lows and bas impact in a I.E.M with the moving Armatures .
I just wish some knowledgeable Dance music fans would give me the Low down on the E-q5's .
