buson160man
- Feb 3, 2011
I suggest the ray samuels raptor.I have owned one for a year and a half.It drives the akg 701 very well.I also have a burson ha-160 and it initially seemed a better match for the 701.But after some time i hooked up the raptor and to my surprise was able to drive the akg phone to a better extant than i remembered when i used it with the 701.apparently the akg seemed to benefit from its pairing with the burson.I do believe that the burson ultimately has more drive ability than the raptor,but the improvement in sound i got when i revisited the raptor was pretty noticeable.The raptor is i believe a much better match than the burson now for driving the 701.The raptor is more expensive than the burson but i believe it is worth the extra expenditure over the burson.The burson is a fine amp and sounds amazing at the price but IMHO the raptor is a more simpatico match for the 701.The burson has a smooth sound,good resolution and the bass has weight and is very listenable with the 701.The raptor in my system seems to be more alive than the burson with much better dynamics.It also seems to have even better resolution than the burson including low level information.The raptor is much more three dimensional.The raptor is my favorite amp at present.I have upgraded the fuse in the raptor with a hi-fi tuning gold fuse.I am also using a kubala-sosna power cord on the raptor.The kubla seems to work very well with the raptor albeit a bit pricey.I think you will like your akg 701 a lot more when you get an amp that can capably drive the phones.
