AverageGuyNC
- Feb 5, 2017
So not much advatage/benefit using a solid wire as far as transferring signal quality goes? That was probably my main question.
I think USB cable quality depends on way more variables than the choice could be simplified to solid/stranded wire. Materials used, geometry, insulation all play an important role.So not much advatage/benefit using a solid wire as far as transferring signal quality goes?
Also, instead of a 1m USB cable, you might want to buy a 1.5m one.
PCM is an all-digital signal and when transmitted over a USB cable qualifies as an all-digital signal transmission. An "analogue representation of a digital signal" would be an analog signal (continuous waveform), not a digital signal.There is no such thing as "all-digital signal" transmission, only analogue representations of a digital signal.
The 1m length could be a problem. Unlike the interconnects where the shorter the better, USB audio cables have to be 1.5m long in order to avoid the reflection issue.He only lists the 1m size, you have to send him a message if you want a different size.
That's exactly what it is in the USB audio cable; an analog signal. Technically, it is a binary transmission in the form of an analog voltage. A series of 0s and 1s transferred as square waves (instead of sine waves) detected by the receiver only when they pass a certain voltage threshold. The all-digital "zeroes and ones" only exist on an abstract, mathematical level in the DAC chip. In reality, the "digital" USB cable is just another analog cable.An "analogue representation of a digital signal" would be an analog signal (continuous waveform), not a digital signal.
Well, it could be and obviously I cannot prove otherwise but I think there's more to this. When different people hear the same thing listening to the same USB cable it suggests that something must be there.Most "differences" people hear between cables, especially ones transferring digital signals, are sorry to say, "in their head."
Honestly, do you believe that people who share the same experience listening to an USB cable are victims of self-hypnotism or a collective hallucination of some kind? I'm not provoking you, would really like to know.
Can I ask an only semi-related question? My DAC is connected to my desktop via a powered hub. If I were to introduce something like an Audioquest Jitterbug (or something comparable like an iPurifier 2) just to see what happens, where in the chain should it go? Between DAC and USB hub, or between desktop (source) and USB hub?
I highly recommend the Chord c-usb cable. Sensibly prices and excellent price/performance and build quality.
https://www.thecableco.com/c-usb.html
Went through more pricey exotic cables and went back to the chord.
So what are you arguing? When the data is transferred from start through the usb, to end, is it binary or not? If the DAC takes in 1s and 0s, and uses this order of 1s and 0s to produce an analog wave, if the 1s and 0s are in the same order, regardless of the cost of the cable, how is the audio output affected?That's exactly what it is in the USB audio cable; an analog signal. Technically, it is a binary transmission in the form of an analog voltage. A series of 0s and 1s transferred as square waves (instead of sine waves) detected by the receiver only when they pass a certain voltage threshold. The all-digital "zeroes and ones" only exist on an abstract, mathematical level in the DAC chip. In reality, the "digital" USB cable is just another analog cable.
