What the $^&# heck is it?.........iFi iEMatch!
Aug 28, 2016 at 4:18 AM Post #121 of 620
You seem to be reading my mind at the moment, first some amazing NOS 6922 tubes and now this! Just what I wanted so I can run my K10s off my desktop setup :D. When will these be avaliable from UK dealers?
Aug 30, 2016 at 4:38 AM Post #122 of 620
Hi,
The global launch is towards early Sept so in the next week or so.
No need to pay, just reserve with one of the dealers on the list.
Aug 30, 2016 at 6:32 AM Post #123 of 620
The next 3 winners are:
joeq70
mp101
jackpot77
Save us answering PMs, the global launch of the IEMatch is around 15 Sept. By all means feel free to reserve with your dealer. They will drop you a line when they have it in-store.
We prefer to wait to everyone has them before we do the global launch.
Cheers.
Aug 30, 2016 at 7:00 AM Post #124 of 620
joeq70
mp101
jackpot77
[tr] [/tr]
Cheers.
Thanks for the update, I have sent the dealer a message asking to reserve one.
Aug 30, 2016 at 9:40 AM Post #125 of 620
Aug 30, 2016 at 5:02 PM Post #126 of 620
joeq70
mp101
jackpot77
Cheers.
Congrats @joeq70, I've never seen anybody win something twice in the same give-away. Must have been some excellent answers.
Aug 31, 2016 at 9:54 AM Post #129 of 620
Hi guys
Very happy to be one of the lucky winners. One quick question - is there anything more to the balanced/SE switch mentioned in your explanation, or is it simply to allow the adapter to be used in both to types of socket?
Just checking there isn't any magic tech in there that will do anything unexpected and turn a pair of SE headphones into a balanced setup by plugging them through the adaptor (hey, I know the physics is unlikely, but I figured I might as well ask!).
Aug 31, 2016 at 10:19 AM Post #130 of 620
Hi guys
Hi,
We're good but not that good!
Having said that, yes there will be more info on how/why we decided to do what we do with the S-Balanced: switchable between SE and Balanced.
Aug 31, 2016 at 10:38 AM Post #133 of 620
A question of Balance (Part 2)
Does this matter? Who cares about balanced headphone connections?
Well, we all SHOULD care.
A key problem with common Headphones and their 3-wire connection is that left and right ground are joined at some point BEFORE the connector and then run together.
The larger 6.3mm Jack Connector already has high enough contact resistances to cause extra crosstalk and inter-channel distortion, especially if the headphone cable is a 3-Wire type. The situation for 3.5mm Jacks is much worse.
With a 6.3mm Jack having 0.02 to 0.04 Ohm typical contact resistance a 50 ohm Headphone will experience crosstalk at around -68dB to -62dB which is generally unproblematic, while with a 300 Ohm Headphone we are looking at -84dB to -78dB which exceeds the channel separation of many electronics.
Yet with a high sensitivity IEM type Headphone having a 12 Ohm Impedance and the around 0.1 Ohm typical contact resistance for a 3.5mm Jack ground connection we only get -41dB crosstalk, something that is inadequate.
Using a balanced connection on mobile equipment will eliminate this issue entirely.
Another benefit of using a balanced connections is that we can create a ‘bridged’ amplifier that will give us four times the output power (two times the output voltage) for the same power supply, something that again becomes especially relevant for portable, battery-powered equipment.
Next time, the hour of the Bewilderbeast.
Aug 31, 2016 at 4:16 PM Post #135 of 620
If this means you are coming out with a new mobile ready balanced amp/DAC, I would like to point out that I did mention that in my entry so I would not be upset if you gave me one of the new balanced amp/DACs.
