What the $^&# heck is it?.........iFi iEMatch!
Aug 11, 2016 at 9:26 AM Post #91 of 620
@iFi audio
The competition is over, so I think it's time for the big unveil now, isn't it?
Aug 12, 2016 at 4:55 AM Post #97 of 620
"The winners will be announced one week or so later."
Put down your pitchforks guys. Should be around the 15th or so.
Yes, you are correct.
The competition shop is closed now. We let it run a little longer as you guys were having fun and we like getting a sample of the thought process because believe it or not it does help us look at how we write user manuals etc.
Thanks.
Aug 17, 2016 at 10:59 AM Post #98 of 620
We thank you all for your patience and for entering the competition. Before we announce the winners, we should divulge the answers really!
It was thoroughly enjoyable reading the entries as they were a hoot.
The iEMatch
1) What is this new product? Where is it used?
iEMatch - it is inserted between the Source and the Headphones/IEMs.
2) What is the first button for – the one on the main barrel (on the left)?
Getting rid of the HISS and excessive LOUDness. From mismatched source amplification and headphones.
3) What is the second button for – the one on the 3.5mm connector (on the right)?
Selection of Single-Ended (TRS) or Balanced (TRRS). This is a connector proposed by iFi audio to make life simpler with SE or Balanced operation on the go. (More on this later).
Why did we develop the iEMatch? The following series of technical notes outlines why we have brought this product to market. We hope you enjoy reading them.
Too LOUD, too much HISS? (Part 1)
Headphone/IEM mismatched
Nearly every High-End Headphones/In-Ear-Monitors(IEM) user has encountered one of the following scenarios.
When the headphones/IEMs are connected to the:
  1. inflight entertainment system
  2. smartphone
  3. A/V Amp, HiFi System or dedicated headphone amplifier
the volume is at the lowest setting but it is still TOO LOUD and between songs there is a LOT of HISS.
This is a mismatch between the Headphones or In-Ear-Monitors and your audio source.
Now one can of course sell the new Headphones or IEMs and buy some that are a better match, except many modern Headphones and IEMs are designed with a very large (around 10 times/20dB) mismatch built-in.
Instead, one can simply add the iEMatch® in line with your IEM’s or Headphones and adjust for the best match with your source.
How bad a mismatch do I have?
Background
Let us take some numbers for sound levels.
Jet takeoff (50m)
140dB
Thunderclap
130dB (Threshold of pain)
Auto horn (1m)
120dB
Chainsaw (1m)
110dB
Loud Rock Concert
105dB
[td=colspan:2] Noise/Sound levels
[/td]
# sustained exposure >95dB may result in permanent hearing loss
Due to the risk of hearing damage it is not advisable to exceed 95dB average SPL and around 115dB peak sound levels.
Mismatch
If we use an iPhone set to maximum (appx. 0.8…1V) and a common HiFi system or in-flight entertainment system (appx 8V) and play music with peaks at the digital maximum, how does a small sample of high-end Headphones and IEMs fare (2)?
* at Ultra sensitivity setting
Mismatch
Acceptable
Good Match
Red (>116dB) is ‘WAY TOO LOUD,’ which means you have a jet taking off or a thunderclap right beside your ears, which is the majority of the headphones sampled fall into.
Amber (113 - 116dB) is borderline.
Green (<= 112dB) is fine.
The loudest headphone (actually an IEM) is a whopping 30dB or eight times as loud as a standard airline headphone. No wonder it will blow one’s head off even at the lowest volume setting on in-flight entertainment.
And with a good headphone amplifier or HiFi system it will produce an unbelievable 155dB, never mind irreversible hearing damage, at those SPL’s tissue in the human ear begins to die off!! (yes, hearing is permanently destroyed).
In addition to irreversible hearing damage, having mismatched headphones/iEMs mean that the annoying background noise (hiss) is significantly amplified and affects the enjoyment of music.
Solution
Most headphones can be matched into the ‘green’ range for comfortable listening using iEMatch® with one of the two settings or at least be brought much closer.
Aug 17, 2016 at 11:03 AM Post #99 of 620
Nice, and I was so close to getting all 3 right! Does 2 out of 3 count for anything?
I am even more curious now that I know what the device, the iEMatch, is used for! Typical iFi, leaving us hanging.
Question/thought: Will the iEMatch be beneficial for my 32Ohm headphones on the 2nd gain setting on my iCAN micro SE, so I don't have to switch the settings back to 0 gain after listening to my 300/600Ohm headphones?
Aug 18, 2016 at 1:58 AM Post #102 of 620
Hi,
Yes, this will work fine. First stage, of 'High-Sensitivity' is the recommended setting. But in due course, when the iEMatch launches at the end of this month, then try for yourself first.
Audio Advisor will be the first dealer to receive these in the USA.
http://www.audioadvisor.com/
Aug 18, 2016 at 4:26 AM Post #103 of 620
This is the product I'm being waiting for :-)
Mojo is a fantastic gadget but for me with my super duper ultra sensitive CIEM the experience has been disturbed by the noise. They are the only transducer I've heard noise out of mojo.
And sometimes nearly ruined my CIEM and ears by not noticed the volume when plugging them in, this will now be over.
Sometimes I have plugged my CIEM to my home rig: iUSB 3.0 > iTube > iDSD micro > iCAN, just to enjoy the fantastic ifi products, but the noise really spoiled the experience.
Of the gear I have in my possession iDSD micro and my iBasso DX90 is silent enough for the CIEM. And for me even if DX90 is a fantastic value it doesn't touch iDSD micro in sound quality and flexibility to tweak the sound as I love to do sometimes. But this new gadget will change the game for me when I'm on the run by making mojo useable with my CIEM.
I hope that ifi as usual sells this thing for a reasonable price. Then I think it could be a game changer and will make gadgets who in the past wasn't able to play together now will be friends :-)
Aug 18, 2016 at 10:38 AM Post #104 of 620
We have taken our time to churn through the answers as the some entries were close to the actual feature and our Skin made the final decision of whether or not it constituted a 'correct' guess or not. Okay this is not the Rio 2016 Olympics but you all get the gist.
The first three winners out of the hat are:
1. rafaelpernil
and
2. Duke40
and
3. Joeq70
Drop us a pm or email
press@ifi-audio.com
to inform of who and where you are so that we can send out the iEMatch to you. PLEASE bear in mind the iEMatch will launch at the end of August so there may be a wait between now and then. For sure the winners will be one of the very first in the world to receive them!
Congrats!
Aug 18, 2016 at 10:41 AM Post #105 of 620
1. rafaelpernil
and
2. Duke40
and
3. Joeq70
Congrats guys!!
