TheDreamthinker
ah ok
so an amp is recommended for the higher end models....
Thanks guys
Thanks guys
The only thing my E7 helped was the anemic bass from the 225i, which forced me to use bass boost on the 225i. Yes, less bass than the Ad900s.
I'm not sure if you had the bowl pads, but I can't imagine anyone who has heard them unamped/flat eq ever consider the bass to be anything but anemic with the bowl pads.
http://graphs.headphone.com/graphCompare.php?graphType=0&graphID[]=373&graphID[]=353&graphID[]=2661
Not that graphs mean everything, but as you can see the bass response isn't much better than the anemic bass on the Ad700s, except the midbass hump, which is largely drowned out by the over emphasized mids and highs. Also, like I said, I think you're the only person on the forums to ever call Grado's "warm" sounding.
I think the most quoted sound signiture of Grado is "a mixture of warm and bright" so I have to disagree with you there my friend.
can't they be described as mid-centred and lively
Well, as you can see in any Grado graph, they aren't really V shaped at all. My personal opinion is because of the design, it allows the bass to be free in the chamber and so it sounds loose and in my ears "warm". Add this to the spikes of the higher end and you will get a "warm and bright" character.
