Google for:
"Kees van der Westen speedster"
That's a proper bad boy. Truly mean machine. Eats rockets for breakfast.
Just the simple leaf tea that you put in boiling water and let brew for at least half an hour. Than you can add citrus or honey or half a lemon with three cloves stuck in it which will give you air while sleeping and cool any tooth ache.Are you saying this about chamomile leaf tea, or Mighty Leaf chamomile citrus, a commercial branded product containing a mixture of Orange Peels, Rosehips, Chamomile Flowers, Lemongrass, Lemon Myrtle, Hibiscus Flowers, Natural Flavors, Spearmint, Orange Petals?
Thank you.
My prepro (home theater) doesn't claim to handle DSD but it does. In fact, it explicitly says it doesn't and yet my one DSD recording sounds pretty good.It's a Yamaha RX-A3030. The manual states 1.4 HDMI. Plus, an old review I found claims it'll play 2 channel DSD via HDMI. So, I think it's time for some experimentation. Now, if I could get rid of the cable ground loop hum, when I patch it into my Saga, for HT passthrough, I'd be really happy!!!
Love mine MoccaMaster. And all the neat colors! Sadly, no red available when we pulled the trigger.Looking at a new drip coffee maker as my old Krupps is getting long in the tooth. Any opinions out there on the MoccaMaster brand?
Not certain if you were playing a digital file or a physical disk; however, most digital streaming software and some disk players will convert DSD to PCM if the DAC is unable to play DSD. This can either be automatic, if the connection supports a bidirectional protocol (eg USB or HDMI), or a manual menu setting that may be set to default to PCM output.My prepro (home theater) doesn't claim to handle DSD but it does. In fact, it explicitly says it doesn't and yet my one DSD recording sounds pretty good.
I say experime
EDIT Second sentence on auto/manual added.
Sure. OTOH, the display on the prepro said something like 1/1Mhz or some craziness instead of 16/44.Not certain if you were playing a digital file or a physical disk; however, most digital streaming software and some disk players will convert DSD to PCM if the DAC is unable to play DSD. This can either be automatic, if the connection supports a bidirectional protocol (eg USB or HDMI), or a manual menu setting that may be set to default to PCM output.
@artur9 @StimpyWan
It is possible the HDMI source is converting the DSD stream into multi-channel PCM and sending it over the HDMI.
Does it sound good? Then you’re golden.
