What a long, strange trip it's been -- (Robert Hunter)
Mar 16, 2017 at 12:51 PM Post #2,417 of 14,565
Yes it is.
The ERC-3 costs less than half and plays beter than most <2K counterparts.
They did what Schiit did.
Build a very good machine for less money than the expensive crap out there.
+1 on the ERC-3.  Super nice CD player...
Mar 16, 2017 at 1:00 PM Post #2,418 of 14,565
  @bosiemoncrieff
I use a Emotiva ERC-3 CD Player / Transport ($499.00), it has a built in DAC (and amp section with RCA and XLR balanced out (true balanced-not sure) ) which I've experimented with into my HA-1, but it also outputs a digital stream as well with Toslink, Coax, and AES/EBU out. I generally use AES to Yggy, Coax to HA-1. 1 year old and no issues to date.
Tascam has a $499.00 unit with similar features and maybe some other versions as well for less. I think Reddog runs a Tascam.
Marantz has one but it's prolly around $1,000 plus, and NAD as well.
If AES is not a priority I think it will simplify your selection to coax and Toslink and maybe the cost as well.
If DSD is your thing the ERC-3 will not get it done for you, but as far as high bit rate stuff, well you've already got a PC hookup to use.
I'm looking at getting the ERC3 primarily due to the AES out.  Can you share your thoughts?  I like the heavy build, the cost, and the digital outs.  Heard some people complain about the CD mechanism.
Mar 16, 2017 at 1:51 PM Post #2,421 of 14,565
Noisy motor... and some build quality complaints.
There are about 10% negative reviews on Amazon about this.  Assuming people with negative opinion disproportionally leave reviews compared to people with positive reviews, then I figure it's closer to 3-6%.  That's pretty good.  Maybe from a bad batch a year or so ago?
I understand there's a flexible return policy.  I'm more interested in the noise during playback and audio quality.
Mar 16, 2017 at 1:56 PM Post #2,422 of 14,565
Which is almost "nil" and no problem at all.
You'll hear nothing of the sort "over the line".
Mar 16, 2017 at 2:06 PM Post #2,423 of 14,565
crap in every way.
Thank you for your assessment, though it was expressed gratuitously.
Thank you @FLTWS for the emotiva rec. I assume I'll get that when I have space for it. If I make the move to Palo Alto, thinking about a that to Yggy to Ragnarok or WA5 for sensitive speakers, presumably in the living room. If I get the Tesla, doubtful I could afford anything more than the Rag...perhaps Vidar.
Can you hook up a subwoofer to Ragnarok or Vidar?
Mar 16, 2017 at 2:20 PM Post #2,426 of 14,565
As a European I cannot be less gratuitous.
Thanks for the compliment.
Anyway, whe're talking schiit here aren't we.
The Cambridge CXC is a reasonable priced transport, no DAC, RCA coax & optical out.  It is available in black or silver.
Indeed it is. I tested it and it's top of the top. Really.
But it'll rip you a hole of 1K
Mar 16, 2017 at 2:48 PM Post #2,429 of 14,565
Got a brand new one a while back for $400 US and see them on Amazon US right now for $500.
r2
  • Back
