matto
- Jun 9, 2010
Do the UM3x have more sibliance than the Westone 3?
The UM3Xs are not sibilance at all, and neither are the Westone 3s, but in general, the Westone 3s are slightly brighter than the UM3Xs.
Quote:The UM3Xs are not sibilance at all, and neither are the Westone 3s, but in general, the Westone 3s are slightly brighter than the UM3Xs.
depends on what tips you use and the fit you can achieve....
Hi all,
I'm just coming off a pair of Head Direct HiFiMAN RE-ZEROs that I really didn't like. They're extremely uncomfortable, the highs are unbearably sibilant and grainy and the lows, while detailed, are seriously underwhelming. Now I'm on the hunt for a pair of IEMs that are everything that the RE-ZEROs aren't, while still maintaining a high level of detail.
From reading W3 reviews I was sure I'd found the right fit - warm and full-bodied, musical, exciting - this is nothing like my RE-ZEROs! Enter W4, and I'm lost again. I guess what I'm wondering is this: do the W4s have proper thump to the bass, do they sound warm and full-bodied and exciting as the W3 does, whilst improving on mids? Is there anything the W3 does better than the W4? I'm looking to avoid anything that sounds too bright and brittle here.
Still, I'm not a basshead by any means. At home I use modded Sennheiser HD 555s (removed the foam tape inside the cans) out of a Xonar Essence STX and after burn-in they sound fantastic at their price range, and the bass is just right.
So, should I look at the W3s or W4s? I'm from Sweden so trying them before-hand is out of the question, returning them probably won't be so easy either, I'm just hoping you guys can point me in the right direction. Thanks!
Hi all,
Larry/HPA: perhaps I missed it somewhere but how do you have a production version of the W4 already? If you have a special relationship with Westone, that is something that should be disclosed to the readership on Head-Fi and added as a disclaimer to your impressions.
I have the Westone 3 and I don't find them sibilant at all. I come from a pair of Audio Technica ATH-CK10 (very bright and little bass) and Sennheiser IE 8 (very bassy and little highs. All this according to my personal opinion, obviously). I find the W3 to give the best of both worlds and the tips they come with have an impact on how they sound: Comply foams for example have an impact on the highs. I find the Shure Olives to be the quite comfortable and producing a nice balanced sound. I said in another post that I've ordered the W4 since if they are going to improve on a sound I already like it would be great!
