Good effort. Never thought about silver from jewellers - I wonder how pure it is?
Four nines (99.99%)
I think your meter to measure L and C is faulty though.
I thought too, but it does measure down to 5pf I am sure, it is a cheap meter, if you recall I did manage to measure other cables down to 30pf and above. It uses 600kHz+ signal
Let's say it is low.
Edit:
Meter is OK! just checked it, see picture. If you zoom in, those are Farnell 22pF +/- 1pF capacitors.
Second picture is measuring the bundled cable from Hifiman
Edition XS Sundara 2020.
With my cables, it stays firmly at zero. go figure!
Cables are a very complex situation, with a host of differing factors at play. One big thing (for speakers for sure, headphones are less critical) is the impedance, so that the transducer is damped. Going down to milli-ohms with loudspeakers is audible, and it changes how tight the bass sounds. But if you use thick cores, then it gets brighter due to skin effects; that's why I use multiple, insulated solid cores, so you get the best of both.
My next project! use 0.2mm silver wire but with 4 insulated cores for each conductor, 16 in total .
Did you try PTFE heat-shrink tubing?
No, I used silicon rubberized heat shrinks for flexibility . PTFE is too stiff for headphones.
I cleaned the wires with Brasso first, polished off, then the heatshrink should keep air out, so I wouldn't get any corrosion in the future.
The treble grain/clarity improvement defies logic. I am not a cable affictionado, it happened by accident!
I just came across some cheap solid core silver wire, decided to do something with it!
Thanx for your thoughts.
