T.R.A.N.C.E.
- Mar 24, 2010
^ seems the pcb on the right is a revision.
If you look close at the area with the resistors, the trace pattern is different where it goes to the lower right pins above the blue resistor that is on the right side.
Very good eye. I asked the Walnut creator and he said those blue resistors were only used to correct a circuit miscalculation which has been fixed in later walnuts
