Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Discussion in 'Portable Source Gear' started by vapman, Dec 8, 2016.
35 36 37 38 39 40 41 42 43 44
46 47 48 49 50 51 52 53 54 55
  1. SuperMAG
    Aha. Thanks alot brother. Was sooo excited to have this. I wanted an dap/amp at similar price.
  2. vapman
    BTW @hakuzen what if you do Walnut line out -> Topping amp -> Senfer?
  3. T.R.A.N.C.E.
    ORDERED 20x Walnuts, no caps, no vol pots!
    Time till my door is 10-12 days including production time and DHL shipping.
    Ordering custom production walnuts is faster than ordering from Aliexpress [​IMG]
    vapman and peter123 like this.
  4. peter123
    Has anyone had the chance to test the Walnut with a pair of Sextett's?
  5. vapman
    SUCH a good pairing! I personally am partial to the HD25 series to the various K240's... not that they are directly comparable, but are more or less designed for similar purposes.
  6. peter123
    Sounds good, thanks! I've got both my first ever Sextett and a Walnut on the way and have a good feeling about them as a pair.
  7. vapman
    After a lot of listening, seems like stuff that generally pairs well with classic/vintage receivers and such get along marvelously with the Walnut. So that basically means everything except gear extremely sensitive to noise and BA gear. I hate BA IEM's personally, so I guess I got lucky there... but I have not tried a pairing I can say is bad yet. Some headphones I have to EQ to enjoy I don't use with the Walnut but everything else I have used is just great....
  8. T.R.A.N.C.E.
    That's where ibasso IT03 comes in, it's DD + BA, and sounds sweet with the Walnut, more so after you do something about the noise of the stock walnut, eg replacing the opamp or the filter cap can get rid of the noise.
  9. peter123
    Yeah, that makes sense. Should be interesting to test it with some of my higher impedance earbuds as well, I don't really have much stuff that's very hard to drive, my modded T50rp are probably the most hard to drive headphones among the ones I own....
  10. nick n
    Peter123 : My excessively modded and therefore very hard to drive T50RP  seems to hit a decent volume , just slightly better than the DT990 Vintage.
    Not sure what you did to yours it's likely a bit more sensitive than mine though.
    Waynesworld will be happy to hear about that AKG K240 success and the T50RP.
    I've only got the 2 vintage K141 silver and gold now. Not had a chance to try them yet.
    Thanks for that idea.
  11. peter123
    Sounds good Nick! My T50rp are basically a BMF DBV#3 mod but with some adjustments through the last three years to suit my preferences. I've got one more pair that I've really only done some basic mods on and added the Alpha Pads on and they're more easy to drive than my "good" pair.
    Anyway I'm really looking forward to try out the Walnut with the Sextett and Fostex in particular but also with some of my earbuds with 320 to 400Ohms impedance.
  12. devleon
    Could you tell me the name on the DAC chip? Sadly can't quite make it out from the picture...
  13. T.R.A.N.C.E.
    I tried finding out more about the chip myself but my search turned up nothing with it's name. Will let you know the chip name when It's daylight here so I can see properly.
  14. nick n
    Originally Posted by T.R.A.N.C.E. [​IMG]
    Also I noticed older walnuts have a difference in the pcb, situated in a crucial area at the dac output, there is two blue crossed resistors, while the newer walnuts have skimped on the production in this area it seems.
    The production dates are left one is September 2016, the right is October 2016,
    ^ seems the pcb on the right is a revision.
    If you look close at the area with the resistors, the trace pattern is different where it goes to the lower right pins  above the blue resistor that is on the right side.
  15. fajrinandro
    I'll standing in line if you decided to comercialized your ultimate walnut someday :smiley:
