spurxiii
- May 18, 2013
http://youtu.be/N7Zc5meSooI
tux!http://youtu.be/N7Zc5meSooI
You still haven't pulled the trigger yet? Better get it before the BEs become discontinued
Can anyone comment on how comfortable they are for long periods of use? this is extremely important for me. Also, you have to stick that thing way inside your ear? because then im not getting them. I want it to sit on the ear and not to fit a lot inside the ear. I don't think thats very healthy..
Being small and over ear, they're quite comfy for long sessions. It may take a bit to get them fitted properly but once they are, they disappear. They are not deep insertion, so as long as you get a seal you'll be good. I'd recommend getting genuine Sony Hybrid tips as I found those to be the most comfortable silicone tips.
I've never heard a DT770 before but based on what I've read of them, but based on the charts and descriptions I've seen any of the GR07s will be better for mixing. The BE is relatively neutral with a bump in the bass by about 3dB...really smooth FR and transitions between the bass to mids and the mids to highs.
I liked more sony xba3 then gr07be
