Does anyone have a Phönix update of if they are closer to being shipped?
Vision Ears and Rhines Custom Monitors (formerly Compact Monitors)
- Thread starter Mimouille
- Tags
- earsonics vision ears
A couple weeks ago they told me the necessary parts were on their way and that once received they'd need to do the finishing work on the IEMs. There was an IG post a couple days ago which showed what seemed to be said finishing of the IEMs so I am optimistically taking that to imply that indeed they are close to the illustrious day of shipping.
danpong
- Dec 14, 2010
I see that you have both VE EXT and Oriolus Traillii. Could you please compare them as they both using same number of EST. It would be really interesting to know if between 2 choice which one would you keep, if you need to choose one and why.It’s different than the Ely…it would be too simplistic to say it’s just an Ely with more bass.
it def has more bass, don’t get me wrong, but to my ear (I only listened to the Ely briefly), the elevated bass relatively speaking de-emphasizes the mids and treble that I heard in the Ely. So, even if for example the mids and treble are technically the same, because the bass is so much more present, mids and treble are relatively recessed.
all in all, i think it’s wonderful and I’m enjoying it quite a bit, but again, IMHO, it’s not really fair to say it’s just an Ely with more bass.
You know the price disparity between them right? haha I would expect at least a little performance difference and the price factoring into which one you'd keep.I see that you have both VE EXT and Oriolus Traillii. Could you please compare them as they both using same number of EST. It would be really interesting to know if between 2 choice which one would you keep, if you need to choose one and why.
danpong
- Dec 14, 2010
ha ha yea I do know the big different price between the two. However, being Oriolus Traillii, is older, I just wonder how will the new EXT stack up against the big guy.You know the price disparity between them right? haha I would expect at least a little performance difference and the price factoring into which one you'd keep.
If you compare the cost of the Ext vs the Bird used the price difference is not so huge anymore. I myself am considering either buying the Ext or Bird used next. I won’t buy the Bird new simply because I personally don’t believe any IEM is worth that kind of money, of course YMMV. I am very interested to hear any comparisons out there between these twoha ha yea I do know the big different price between the two. However, being Oriolus Traillii, is older, I just wonder how will the new EXT stack up against the big guy.
I'm not great at articulating what I'm hearing, but I'll try and give it a shot. Fair warning - my preferred cable for the Bird (a gold-plated silver) is on it's way to get re-braided, and so I can't do an A/B at this exact moment. With the EXT, I am using a Norne Silvergarde SX 8-wire cable.I see that you have both VE EXT and Oriolus Traillii. Could you please compare them as they both using same number of EST. It would be really interesting to know if between 2 choice which one would you keep, if you need to choose one and why.
While it's true they both use 4 EST, they are otherwise very different. As you know, apart from the ESTs, the EXT uses DDs while the Bird uses BAs. Ultimately they are both wonderful in their own ways, and so I think if you had to choose one or the other, it'll come down to preferences - I am fortunate to not have to choose In other words, I don't know that I can look at either and fault it for a particular reason...which I can certainly do for other IEMs I've heard and sold.
The EXT is warmer sounding overall, with a more U-shaped sig (some may call it V...and I could agree with that as well). While I'm not sure the bird has a reference tuning, it's flatter and more reference-like than the EXT.
The EXT has wonderful, DD bass. While the bird has some of the best bass I've heard, particularly considering it's just 2 BAs, I would probably say I prefer the EXT's bass (but again this would be due to preferences and not because I think the bird's bass is bad per se). EXT has wonderful rumble, nice sub-bass emphasis, I don't detect much bleed into the mids (if any at all). Very nice implementation from Vision Ears.
Mids are interesting. EXT is the first IEM I've heard using a DD for mids. I'd say this is a wash between the two; the DD brings a unique sense of layering and detail to the mids that I've not experienced before, but I still very much enjoy the mids on the bird. hard to choose one versus the other. I do find myself a bit more enamored with the EXT's mids right now, in part because of the additional detail I'm hearing in vocals that I've not heard before.
On treble, I'd have to do another direct A/B before giving comments with a high degree of confidence. What I can say is that both have implemented ESTs very well - I'm particularly sensitive to peaky/shrill treble (and upper mids), but while both the EXT and Bird bring a somewhat characterisitic brightness and clarity to treble (characteristic for ESTs, based on what I've heard), I don't find either to be overly bright or shrill in any way. The bird's treble comes off as a bit more forward in the mix given the EXT's tuning, but I also wouldn't say the EXT's treble is recessed in anyway. I don't consider either to have particularly airy treble, just to my ears - my benchmark for airy treble is frankly the U18s...something about those Tia drivers I suppose.
Apart from the sound signature, I'd say the bird is slightly more detailed, whereas the EXT is more musical. Stage is slightly wider left-to-right on the bird, but the EXT is no slouch here - excellent stage width.
Not sure I can choose one over the other, at least right now.
Hope this helps!
danpong
- Dec 14, 2010
Thank you very much for your impression. This really helpful. I’m trying to pick between the two and really hard to decide LOL.I'm not great at articulating what I'm hearing, but I'll try and give it a shot. Fair warning - my preferred cable for the Bird (a gold-plated silver) is on it's way to get re-braided, and so I can't do an A/B at this exact moment. With the EXT, I am using a Norne Silvergarde SX 8-wire cable.
Hope this helps!
I understand...not an easy decision. For now, I'll keep both. My guess is that the EXT will get more ear time (in fact I am listening to them now!), but only because it hits my preferences a bit better than the Bird. The Bird, Erkly, etc., will provide a nice "change of pace."Thank you very much for your impression. This really helpful. I’m trying to pick between the two and really hard to decide LOL.
I presume demo'ing each is not possible for you, which would of course be ideal.
I believe VE is shipping out their first "big" batch of EXT's now, and so perhaps you'll be able to read more impressions of it shortly, which may be helpful to you in lieu of being able to hear them.
Gavin C4
Member of the Trade: Hercules Audio
VE definitly nailed it for this one. Good Job.
Is the silver mesh-like structure in the groove of EXT actually an open design? Or is it just surface texture?
There are actual perforations there. They essentially function like the vent holes you’d find on most DD-equipped IEMs. But, the gaps aren’t as wide as, say, the ones on 64 Audio’s Duo, so I wouldn’t consider them an open or semi-open design at all; just a more aesthetically-pleasing interpretation of the DD vent hole.Is the silver mesh-like structure in the groove of EXT actually an open design? Or is it just surface texture?
Agreed, I’m rocking that same combo EXT + Centurion, it’s such a great and resolving IEM on its own and then tossing on that cable just makes it even better in detail retrieval!
Now that's a pretty cool way to integrate the vent into the design!There are actual perforations there. They essentially function like the vent holes you’d find on most DD-equipped IEMs. But, the gaps aren’t as wide as, say, the ones on 64 Audio’s Duo, so I wouldn’t consider them an open or semi-open design at all; just a more aesthetically-pleasing interpretation of the DD vent hole.
Total: 12 (members: 0, guests: 12)
