Pharmaboy
It's odd, most people seem to be running their Violas at -12 dB. We better hope Fried doesn't read the posts and start shipping low power amps for girly-men
I must be a girly man--one of my favorite amps is low power (M Stage Matrix HPA-1).
I suspect the reason that many run their V281s at reduced gain is due to 2 factors:
- There seem to be more relatively efficient, high sensitivity headphones out there. You can readily see this (for example) in the high-end offerings from Audeze, Hifiman, Final, Meze, etc.
- I also suspect that more DACs are departing from the nominal output voltage of 2V that used to be standard. It would be very hard to prove this, admittedly. But reading DAC specs, I come across higher-than-usual outputs fairly often.
