Navyblue
- Apr 2, 2008
Most receivers are going to have more than just 2 inputs.
But what does it have to do with "listen to another source without turning on your main system"?
What is a "standard headphone jack setup" anyway? Any decent speaker amp is going to have a lot more power than a headphone amp, so much so that resistors are needed to prevent the headphone getting fried.
As for quietness and dynamic, some are better, some are worse. The same applied for dedicated headphone amp. Apparently you are not reading the relevant threads enough, the myth and assumption that you mentioned has actually been discussed in those threads.
If you read earlier postings in this thread, you'd find someone actually sold off his MkV and settled with an integrated amp.
Originally Posted by musiclover45 /img/forum/go_quote.gif To me, it just makes sense to have a dedicated headphone amp. With the MKV, you have two selectable inputs, so you could listen to another source without turning on your main system. Having that flexibility is very nice indeed. |
Originally Posted by musiclover45 /img/forum/go_quote.gif The MKV is going to sound better than a standard headphone jack setup. It has much more power and was built to be quiet and very dynamic. |
