Output thread 0xf05fa000, name AudioOut_19D, tid 6997, type 1 (DIRECT):
I/O handle: 413
Standby: no
Sample rate: 44100 Hz
HAL frame count: 1792
HAL format: 0x6 (AUDIO_FORMAT_PCM_24_BIT_PACKED)
HAL buffer size: 10752 bytes
Channel count: 2
Channel mask: 0x00000003 (front-left, front-right)
Processing format: 0x6 (AUDIO_FORMAT_PCM_24_BIT_PACKED)
Processing frame size: 6 bytes
Pending config events: none
Output device: 0x8 (AUDIO_DEVICE_OUT_WIRED_HEADPHONE)
Input device: 0 (AUDIO_DEVICE_NONE)
Audio source: 0 (default)
Normal frame count: 1792
Last write occurred (msecs): 8
Total writes: 1312
Delayed writes: 0
Blocked in write: yes
Suspend count: 0
Sink buffer : 0xefebb000
Mixer buffer: 0xf03f4800
Effect buffer: 0xf0f64800
Fast track availMask=0xfe
Standby delay ns=1000000000
AudioStreamOut: 0xf1495880 flags 0x400001 (AUDIO_OUTPUT_FLAG_DIRECT)
Frames written: 2351104
Suspended frames: 0
Hal stream dump:
Stream volumes in dB: 0:-10, 1:-20, 2:-23, 3:-13, 4:-23, 5:-23, 6:0, 7:-18, 8:-22, 9:-96, 10:-21, 11:0, 12:0
Normal mixer raw underrun counters: partial=0 empty=0
1 Tracks of which 1 are active
Name Active Client Type Fmt Chn mask Session fCount S F SRate L dB R dB VS dB Server Main buf Aux buf Flags UndFrmCnt Flushed
none yes 6279 3 00000006 00000003 1065 26460 A 3 44100 0 0 0 00232A00 F0F64800 00000000 0x000 0 18690
1 Effect Chains
2 effects for session 1065
In buffer Out buffer Active tracks:
0xf0f64800 -> 0xf45b3000 0xf45b3000 -> 0xf0f64800 1
Effect ID 651:
Session Status State Engine:
01065 000 003 0xf14a6840
Descriptor:
- UUID: 337377E3-92FC-4F0B-B677-EAEB249EAEE6
- TYPE: 534E176F-456C-4EF4-8099-D7BA766AB0FA
- apiVersion: EFC0EC3C
- flags: 0040004C (conn. mode: postproc, insert pref: first, volume mgmt: implements control, input mode: not set, output mode: not set, offloadable)
- name: lgmqadummy
- implementor: LG Software Ltd.
- Input configuration:
Frames Smp rate Channels Format Buffer
01792 44100 00000003 1 (AUDIO_FORMAT_PCM_16_BIT) 0xf45b3000
- Output configuration:
Buffer Frames Smp rate Channels Format
0xf45b3000 01792 44100 00000003 1 (AUDIO_FORMAT_PCM_16_BIT)
1 Clients:
Pid Priority Ctrl Locked client server
6279 0 yes yes 0 0
Effect ID 667:
01065 000 003 0xf2c20290
Descriptor:
- UUID: 08B8B058-0590-11E5-AC71-0025B32654A0
- TYPE: 08B8B058-0590-11E5-AC71-0025B32654A0
- apiVersion: F2C48218
- flags: 00C00280 (conn. mode: insert, insert pref: any, volume mgmt: requires indication, device indication: requires updates, input mode: not set, output mode: not set, offloadable)
- name: Volume listener for Music
- implementor: Qualcomm Technologies Inc.
1 Clients:
1161 0 yes yes 0 0
Local log:
11-04 11:37:22.288 CFG_EVENT_CREATE_AUDIO_PATCH: old device 0x8 (AUDIO_DEVICE_OUT_WIRED_HEADPHONE) new device 0x8 (AUDIO_DEVICE_OUT_WIRED_HEADPHONE)
11-04 11:37:22.307 addTrack_l (0xf092f600) none no 6279 3 00000006 00000003 1065 26460 A 1 44100 0 0 0 00000000 F0F64800 00000000 0x000 0 0
11-04 11:37:52.838 removeTracks_l(0xf092f600) none no 6279 3 00000006 00000003 1065 26460 I 1 44100 0 0 0 00148200 F0F64800 00000000 0x600 0 18690
11-04 11:39:41.369 CFG_EVENT_CREATE_AUDIO_PATCH: old device 0x8 (AUDIO_DEVICE_OUT_WIRED_HEADPHONE) new device 0x8 (AUDIO_DEVICE_OUT_WIRED_HEADPHONE)
11-04 11:39:41.374 addTrack_l (0xf092f600) none no 6279 3 00000006 00000003 1065 26460 A 1 44100 0 0 0 00148200 F0F64800 00000000 0x200 0 18690
USB audio module:
No output streams.
No input streams.
Reroute submix audio module:
route[0] rate in=0 out=0, addr=[]
route[1] rate in=0 out=0, addr=[]
route[2] rate in=0 out=0, addr=[]
route[3] rate in=0 out=0, addr=[]
route[4] rate in=0 out=0, addr=[]
route[5] rate in=0 out=0, addr=[]
route[6] rate in=0 out=0, addr=[]
route[7] rate in=0 out=0, addr=[]
route[8] rate in=0 out=0, addr=[]
route[9] rate in=48000 out=48000, addr=[]
