On my rooted DP-X1 - if the V4A FX v2.5.0.4 driver is installed/enabled, then UAPP v5.0.3 will not operate in HiRes or Bit Perfect mode, apparently due to driver conflicts.
If the V4A driver is enabled, and UAPP "Internal Audio Driver" is set to "HiRes Direct Driver", it won't play music, and displays "Failed to find or setup HiRes DAC!".
If the V4A driver is enabled, and UAPP "Internal Audio Driver" is set to "Original Android Driver", and "Internal HiRes Audio > Bit Perfect Mode" is not set to "Off", then the audio that does play is very distorted.
UAPP does play music, with V4A effects enabled, when UAPP "Internal Audio Driver" is set to "Original Android Driver", and "Internal HiRes Audio > Bit Perfect Mode" is set to "Off".
But the V4A driver has to be Uninstalled, and the DP-X1 rebooted, before UAPP can use its HiRes driver / Bit Perfect mode.
Is there some log data that I could provide, which could be used for a workaround, that might allow both drivers to be loaded and switched between (without having to reboot)? Thanks!
