lmservas
Davy, I'm starting to lean towards an issue with the beta firmware? The following from the log file repeats with each attempt to play a track:
018-09-13 22:16:01.017: Retrying: isPlaying() = false
2018-09-13 22:16:01.023: linkSpeed = -1 Mbps
2018-09-13 22:16:01.032: Metered network!
2018-09-13 22:16:20.197: Play Android, HiRes = true
2018-09-13 22:17:11.250: linkSpeed = -1 Mbps
2018-09-13 22:17:11.263: Metered network!
2018-09-13 22:17:11.296: Exception in HTTP seek! java.lang.IllegalStateException: Unbalanced enter/exit
2018-09-13 22:17:11.301: IllegalStateException in fetchData! closed for Tidal2018:09:13 22:17:11.302 AV init: Couldn't open input http://ab-pr-ak.audio.tidal.com/685...fb961f374e543b20180bf479801f59090b1b6f1ce01a1, res = Network dropped connection because of reset
2018:09:13 22:17:16.305 Couldn't acquire 1st lock in play!
2018:09:13 22:17:16.315 getTotalLengthMilliseconds() called when sample rate = 44100
This is an issue with the network/devices handling of the connection correct?
