mlantinen
Member of the Trade: Martin Custom Audio
- Dec 1, 2009
@schwally, those look great. I'll be sanding mine tonight. I think they look pretty good the way they are too but I'll definitely be doing mine up.
good job! they look good without the front of the wood sanded, leaving the writing with the old varnish. This will show their history rather than making them look brand new when you have finished.
Marvelous.
That was a good idea to stay away from the tops. I did not have as much luck sanding and restaining. The lettering on mine is not in the best shape now.
Thanks Luggy!
Also, I've got a surprise for anyone who cares. I stopped by Woodcraft today and had a pretty good idea (inspired by another member) and picked up some awesome stuff. I'll try to work on them tomorrow and post. Tonight I've got other plans but honesly I'd rather work on these. Picked up a new chuck that will fit the inside of the cups perfectly and will be much, much more stable, accurate, smooth and less dangerous. I'm psyched out of my mind man!!!
Well Schwally, if it makes you feel any better, I kinda screwed up one of my cups yesterday too. Hopefully most people won't be able to see it. The trouble is, I will be the one mostly looking at it and I know the inconsistencies are there. Oh well. My new idea should hide one of the inconsistencies but the other will remain.
Hey, and I think you're the one that said "they're just headphones"
The drivers!!!!! That's where the magic is. As long as the drivers stay in working order, you can play all day long with they're housings to get a satifactory if not stunning look.
Once I get my lathe up and running and figure out how to turn cups, maybe I'll turn a new set for you as a replacement. Keep your originals as to help tell the story of they're vintage but use the new ones. Now that we know how to take them a part, it'll probably be relatively easy to switch out cups as long as we use hot glue or something similar that's easy to remove the drivers.
Update: Well, I spent about 8-10 hours in my garage on Saturday and a couple yesterday just dinkin around and it turned out be a pretty productive weekend. Learned how to use my lathe alittle better and with the combination of an adjustable hole saw for my 1/2 HP drill press, lathe (with a small and medium size chuck), my Ryobi band saw and my Ryobi bench top sander I was able to turn a couple pieces of leopard wood into accent pieces for the ear cups. Sorry, I didn't get any pics of me using the lathe with the lathe tools, just the lathe for sanding. I'll be going full tilt now though, so tonight I think I'm going to try another pair to see how they turn out, so I'll likely take pics tonight.
Anyway, here's pics of the intense, sweaty action. You can see my mockup in the upper corner. Note: This wasn't supposed to have two vertical center lines. The right one wasn't used.
Now at this point I only went most of the way through the wood. I didn't know what would happen once the chisel made it's way through the last bid of wood and there was a loose ring. I envisioned the loose ring would somehow get crushed. So I used the band saw to carefully cut around the remaining bit of wood then put it on the lathe and sanded down the outside with a little block of wood and 80 grit/320 grit/400 grit/ 600 grit. The inside of the ring doesn't really matter as far as sanding goes since it will be inserted onto the outside edge of the RS1 cup.
They still need final sanding, staining, and finishing. Of course the second one snapped on me when I exerted alittle too much force attaching them to the lathe. I used wood super glue and clamped them over night. Yesterday morning it was good as new. You can't even tell where it broke. Also, some how the second ring is much looser than the first. The first one fits snug but it might be better to have it alittle loose since the glue will need some space. ?? I'm not sure yet. I'd rather have them fit snug and using as little glue as possible in case I want to take them off. So, I'll try to turn a new set tonight and see if I can get a snug fit for each of them.
-Marty
cool stuff man. I think it would be fun to have access to those tools.
Ohohoho. This is getting awesome looking.
