- Aug 12, 2007
Amazing thread. One of the best I have seen at Headfi.
Yup, they just rest in there. Yeah, it's a pretty big gap but not worried about it. Can fill with wood glue or wood putty. I'm sure I'll figure out something.
How did you get your metal screens out? Mine are really stuck in there.
Quote:Amazing thread. One of the best I have seen at Headfi.
+1
Ya doing a fine job!
looks amazing! great work with the dremel, i would scare myself. . .i have not-so-steady hands.
if you dont mind me asking. why did you sand the plates between the driver and your ear? and how did you manage NOT to fill them with dust from the sanding?
you can spray goo gone extreme on the screens and take the black off. The silver screens with a dark wood would look nice also.
Push on them really hard. there are 2 or 3 glue dots holding them in place
Good idea, but I'm still leaning toward some sort of copper screens if I can pull it off. Orrr...
***What does everyone think of White Sleeving just like my old Denon's in my sig PLUS, White Painted Screens with an irridescent coating? Would that cheapen the look of them?
Dude, I used the dreml on them last night to chip all the glue and then some, and they are like digging into the side of the cup. I'll look at the other cup tonight to see if it's the same way.
before i screw my cups up anymore, how are you planning to sand the cups down. Im curious hoe a dremmel abrasive buff might do on them.
Ha, yeah, I actually tried one fo the abrasive buffers on the face of one of the cups. You can see it in my pics from last night. It works ok and may indeed work for the whole shootn match but in my opinion it would only be used to strip most of the old stain/varnish. Then i'd use sandpaper rolled up in the hand and twisting the cup to get a uniform finish.
I should mention that I do have a lathe, but I haven't tried it yet. I bought it last fall and I think I bought a chuck that will allow me to grip the cup and spin it for sanding. I plan to use it more to turn all sorts of stuff. I'll have to shoot Bill a few messages for pointers if he doesn't mind.
Also, I hesitently am mentioning that I actually purchased a DIY CNC machine about four months back from Kickstarter. Yes, I plan to use this for all sorts of goodies just like Calico does here on the forums. But it's going to be an incredibly steep learning curve and who know how long it'll take to learn how to use it, much less put the thing together. I still haven't received it since I'm waiting for the developer to finalize the USB operation rather than parrallel.
@schwally,
That is a good question that I'm not ready to answer as I haven't tried the 320 on my cups yet. I would maybe try it out on the inside of the cups first to see how it goes. But I suspect it would be just fine because you'll need to remove quite abit of stain and laquer to get back down to the wood. You can always rebuilt a few mm of finish with several coats of laquer. I'm planning on going nuts to get a really shiney and thick layer.
But hopefully I can figure out my lathe tonight. that would be ideal.
***I wonder if it's possible to jury-rig a drill attachment to slip the cups over, so you can spin and sand them? Something to think about.
