But... clear ones change color over time... some turn green, others yellow...
Ultimate Ears Triple Fi 10 Thread
- Thread starter NeObliviscaris
- Tags
- shure-e2c-sound-isolating-earphones spider-realvoice-vertical-in-the-ear-headphone ultimate-ears-triple-fi-10-pro-earphones-gun-metal-blue-with-roadie-case westone-3-true-fit-earphones shure-se530-sound-isolating-earphones in-ear westone-um2-stage-monitors ultimate-ears-super-fi-5-pro-earphones-clear westone-4-true-fit-earphones
illquid
- Mar 3, 2011
I have a pure copper LOD, but have a pure silver one being delivered. Currently using the very portable ibasso, so don't mind carrying a slim amp, looking at the Arrow next. Going to A/B copper and silver LODs and see if it makes sense going copper to silver for the actual cable, I do realise that the LODs are much shorter in length to the cables but, I think it might still make a meaningful comparison.
Although part of me thinks that we are trying to change the signature TF10 sound through various upgrades and accessories, which is why I've also ordered SM3s, to use for more vocal and some of the treble intense tracks I listen to. I will definitely not be leaving my TF10s though, I've got custom eartips on them that make them a delight to wear which don't really work with the SM3s.
You make a very interesting point on braided wire Mad Max, I've always heard the opposite to what you said. Isn't braided wire supposed to reduce the skin effect of conductors? Why do you think braided cable should be avoided?
In my experience, braiding kills soundstage, clarity, and detail. It's like adding crappy, passive crossfeed or something. I've read about people throwing around this "skin effect", personally I think it's hogwash.
It may be true, but it seems to be the only reason to go with Litz-like braiding, at the cost of a number of other factors as far as sound. I will need many reasons not to go with twisted pair like pros do. In fact, the head-fiers who have recommended braiding recommend it for when you go four conductors per channel. You do two four-conductor braids (one per channel) then twist the two braids together. Otherwise, I say twisted pair for a four-wire stereo cable. You don't want to bottleneck unnecessarily the already small difference cables make... well, in my opinion.
illquid
- Mar 3, 2011
I see, just out of curiosity, is there a reason why it kills soundstage etc? Litz braiding is proven to reduce the skin effect in certain applications, this is not to imply that the actual braiding we get is "litz", but I've never heard any scientific reasons why it would be detrimental so far, as I have opted for some braiding on my new LOD (which may have been a mistake)
It increases crosstalk. Bad for the soundstage. Bad for other aspects of the sound, it seems to me. I'm not saying that is all there is to it, I've told you my observations. With twisted pair done correctly, the ground wires separate the signal wires from each other slightly throughout the entire length of the cable, which seems to make all the difference.
h3rb
- Sep 21, 2009
Loved my TF10s when i first got them, but its time to move on. Going full headphones.
calipilot227
UPDATE: Just got my replacement cable from UE in the mail today (free replacement under warranty). It was slightly delayed due to the fact that the cables were on back order, and they must have been out of the standard cables because they sent me a TF10vi cable! (That's the one with the mic and remote for the iPhone/other smartphone). It works with my enV touch as well, but the music player on it is terrible so I never use it (and the high noise-floor creates background hiss that is often louder than the music itself). Now I understand why everyone raves about UE's customer service
Also, the vi cable is much nicer than the original TF10 cable, notably the rubber on the outside is softer and the memory wire isn't as rigid (makes it easier to adjust).
Same here... Still quite impressed whenever i go back to them, but my still minty Ed8s are THE phones now
mrAdrian
- Apr 27, 2011
Just joined the 10pro party ~
So sad to hear from post #1 has moved to Westone ><
Welcome and enjoy them! Well, at least we have the ease of simply replacing any broken cables unlike the Westone 3 that he has switched to~ Silver cables and a suitable amp that matches your player would help bring out the mids should you need more of them
matt9292
- Jul 11, 2009
I've had mine for almost 3 years now and they're awesome and I've always loved their sound. Also got some great customer service, the original cable broke and since I'm in Canada and you can't order off of their site, they sent me not one but two new cables. They've always been great except for the crackling in the left earphone at certain frequencies over the past month or so
mrAdrian
- Apr 27, 2011
I bought them from some other owner who has recabled them, yet due to convenience i might buy the stock cable for the mic. hmm
nivrethejugg
- Feb 2, 2011
Guys, is getting a better cable for them worth it?
illquid
- Mar 3, 2011
Its not if you can get an amp with the same money. It should really be the last thing you upgrade, unless you just want something that looks better, because that's at least guaranteed.
scottiebabie
- Jul 13, 2006
the short answer - YES to my ears atleast. i have NullAudio Lune cable & i could discern better everything but the main thing that hit me are the better & more forward mids. all in all, a worthwhile endeavor if u can get one used for <$40.
agreed. to my ears, my Lune cabled TF10 doesnt require an amp to sound good either of a sansa fuze or a sony s616. whats more important is getting the 'correct' tip. for me, its a reverse medium black olive. removed the bottom blub & tighten up the bass (of a comply tip) & also significantly reduces the treble sharpness (of a silicon tip) - basically i got the best of both worlds.
try it & be amazed! i was
Total: 26 (members: 0, guests: 26)
